Is it okay to run with out power steering?
97 nissan maxima gle. Power steering pump is making alot of noise and has a real bad wobble to it. Is it okay to run without power steering belt or is it gonna make it impossible to drive. Just need to go a week or so until i can replace the pump.
you can run without it, but as said when youre trying to back out of a parking spot its gonna be a bear to turn the steering wheel. by the end of the week your arms are gonna look like Popeyes lol
Power steering is only needed when the car is at a standstill (or at really slow speeds). Once moving, power steering is no longer necessary and the steering can feel normal and safe. The only concern will be with the rack and pinion over time. Depending on the design, a power steering rack and pinion may wear out sooner when their is no power assist. I have driven manual r&P and actually have an mr2 that came with a manual r&P, you get used to it over time.
Cut the power steering belt off and drive for a week when u get the pump put a $10 new belt. They have to take the belt off to put the pump so the extra cost is only the belt which is like $10
Having a disconnected power steering rack is different than driving a car with a manual steering rack. You can run with it disconnected, but you're gonna fight it trying to turn it tight while parking driving at low speeds. The remaining fluid inside your steering rack will also work against you since it's not being pumped thru. If you have another car to drive until you can get your Max repaired, i'd recommend doing that.
I actually got one from a local near me. He has a 5th gen in which he was swapping out a blown motor and he sold me the crank pulley to me for cheap. The crank pulleys from 1995-2001 should work on yours.
pkfinn
Jan 3, 2016 02:55 PM
Mrbizness1
Aug 18, 2015 08:43 PM
