99 max with security light always on
Well I just got done with the 3.5 swap in the car and now the security light will go out and is killing ignition and fuel. I tried to get a locksmith to reprogram the key and his programmer was having a problem with communicating with my car.
well just got the time for the second locksmith but no luck at all. Hes code reader just said that it could not connect. Now the first locksmith plugged his reader into the obd1 gray plug. the second one plugged it in to the obd2 plug. but both had the same out come. As for the ECU I don't see how the ecu can go bad just by the car sitting around and it worked just fine before i put the 3.5 swap in. Is there anything else i'm missing with the swap that is making this happen. I got 18 days before deployment. I really want to hear her start and its kicking my butt.
12 volts has to be on one of the pins in both the Consult and OBD connectors. Check 2 fuses, fuse # 13 (10 amp), middle column 2nd from bottom and fuse # 40 (7.5 amp) top right corner.
While these fuses also supply power for other things, you might not have noticed them at this point.
rbaker100
Aug 28, 2015 08:11 PM
