So How Complicated Is This? ... Trans Filter Replacement
I've tried to do a bunch of searching and a bit of reading and even went to the FSM.
However, I have, up to now been unsuccessful in locating the procedure for the removal and replacement of our transmission filter.
In shopping for the piece I ran across an advisory stating, "replacement of filter requires valve body removal."
So, instead of searching the FSM for the written procedure, I thought I'd have a look at the exploded graphics ... sure as sh*t.
So ... how complicated is getting to and pulling this thing so's a new one can go in?
There is no need to replace it. It's a screen as Ameri said. When I took mine out, I just cleaned it. There were some small metal shavings that I removed with some tweezers and place it back. Valve body removal is not required. When you removal the trans. pan you will see the screen held by a screw or two.
Very easy.
For guidance on dropping the pan and screen read post 399 of this thread
http://forums.maxima.org/fluids-lubr...-level-10.html
some had to remove the valve body because the screw in the middle sometimes had to be held on the other end. another thing to note you should clean out the little screens on the shift and t/c solenoids. this actually caused drivability problems for my dads car where he thought the trans was gone. but we...well i replaced the shift solenoid kit and filter and shes still rolling at 200k
vingodine
45
May 21, 2016 12:46 PM
Starrider
Sep 17, 2015 07:26 AM
kirkhilles
Aug 8, 2015 10:53 AM
