What can be trigging my ABS TCS OFF and SLIP lights on?
Have you checked to see if you still have ABS breaking. In a safe place push on the breaks hard and see if they lock-up or not. Just be careful, if they do lock up remember you won't be able to regain steering control until.you let off the breaks.
Usually, when all those lights come on together like that you have a misfire. Has the car shaken or jerked at all?
Is the CEL on? You need to pull your codes.
But yeah, usually this is how a misfire presents itself.
That's not a misfire...
Advance may not be able to pull ABS codes, check for a failed wheel speed sensor. There is a way to jump terminals on the diag port to make the ABS light flash the code. Search this site.
Is your speedo and tach working correctly?
Lastly, check the voltage at the battery, make sure your charging 13.5 to 14 volts when the engine is running.
Yellow lights everywhere
i have the same issue...been getting idling misfire, in turn now my abs slip tcs light is on and jus recently now my service engine soon...need to run codes asap!
Those lights should go off after restarting the car...If they dont, probably a pretty bad misfire.
What actually is a misfire?
Can someone give us a clue as to where to start looking? Thank you..
Did you all check this site?
ive a post or two in this onions of years back when had my 05 ....
start with simply cleaning the abs sensors with some soap and water.
Then go from there. ....
... check the forum.
Greetings.. First time to post here.. My daughter's 2008 maxima will die without notice.. be hard to start.. and sometimes shutter as she is driving and then die? The TCS and SLIP lights usually come on simultaneously... Usually though... once it is started.. it may not do this for days? and at some point after.. will restart and run perfectly with plenty of power to spare..
mrminecraftpro421@gmail.c
Jul 10, 2017 07:26 PM
xUltra
21
Sep 23, 2005 11:29 AM
piotroosh
May 27, 2005 07:11 AM
