Help Needed: Milky Substance in Intake
Hi Guys,
In an effort to help my gas mileage, I replaced one of my primary O2 sensors tonight. Also went to clean MAF sensor filament. Noticed it was oily in the intake accordion tube, and when cleaning the gasket between the two halves of the box in the middle of the accordion tube (the resonator) slipped off, so I took everything up to the throttle body off. When I took one of the two large hoses off of the intake tube, there was some milky water/oil in there. I then decided to check my oil and it was on the low end of the dipstick. I don't want to jump and assume the worse, but does this point to a bad head gasket? No overheating problems ever. New PCV valves as well. EGR is throwing a code (probably plugged tube). Can the resonator be taken apart to reseat the gasket? Look glued together to me. Thanks!
It was creamy colored, definitely looked like some water with it as well. I fixed the gasket inside the resonator (since I found it's glued together and doesn't come apart to fix easily), wiped everything as clean as I could, cleaned MAF filament, and put it all back together. Seemed ok on test drive. Oil was a little dirty, but looked normal, and radiator was full and coolant still looked green and clean. The milky substance was coming from the hose that connects the front head to the resonator. Surprised PCV system would be causing issues since PCV valve has maybe 3000 miles on it. Is there anything else that can get plugged up? Thanks!
I've had that on a couple cars I've owned. Usually happens in the winter. My best guess, is that the oil does not heat up enough for the water to evaporate off completely, and some of it condenses in the PCV hoses. I cleaned out the hoses, and have never had a problem.
usually this happens on older peoples cars when they just make a 5 minute drive to the store twice a week, oil doesnt get warm so the PCV cant get rid of the moisture and it builds up
maxima297
Sep 30, 2015 03:32 PM
