torque pressure sensor
New mechanic I got for my car..
Maybe I got the part wrong... I will confirm. Usually it's something located on the pedal but our cars are different.
Throttle position sensor
2002, pulled a 220 code, will check when I get home.
I need new dashlight display lights for my car, can I pick them up at pepboys or autozone?
Well, it's located on the throttle body so I'd have to buy the whole part anyways. I might as well, I'll pull the code once I get back home but most likely.
Also the clutch sticks to the floor lol, I think it has a air leak.
I'm getting a price of 600 bucks for it, I just need the throttle body, someone post a link from a good website to buy from? and do I need oem or aftermarket?
www.car-part.com
www.nwpengineering.com
www.courtesyparts.com
www.rockauto.com
www.thepartsbin.com
I thought it was included in the throttle body but it seems to be sold seperate.
http://www.partstrain.com/store/??N=...universal:0%29
I'm getting 420 and 430 codes...
Resoantor wont do you any good.
http://www.courtesyparts.com/22620-t...ml?cPath=1956&
$16 cheaper here:
Thanks, I'm debating buying only the switch vs the refurbished tb and swith? Isn't it possible to just clean the throttle body without having to change it?
Also, I want to get rid of the cat, it's factory and never been changed, what's the cheapest way to do this while limiting the noise? My mechanic says take it to a muffler shop, remove it and install a resognator but someone on here told me that's a bad idea.
Test pipe?
If your car is an 2002, then yes, the TPS/APPS will definitely throw you a code. And it would go into limp mode of the voltages aren't within a certain range of each other and you wont be able to break 5 MPH.
Also, not sure why you want to do the test pipe. I've seen cats las a long time. It' more so your pre-cats that will cause problems.
What's your car idling at now?
JoshG
51
Sep 21, 2015 10:41 PM
RWCreative
Sep 21, 2015 11:01 AM
Any more elaborations on who told you this?
