Anyone think its worth having my Intake manifold ported and polished?
A guy i know does porting & polishing for intake manifolds. I was thinking about having this done. I know i will only gain about 4-5hp NA but i am juice. I al also running a higher flow fuel pump and im sure that will help out the higher air-flow. What are your thoughts?
I was also thinking of having him bore my TB out a little. Again, ideas?
Unless this guy really knows what he's doing (has lots of experience with this engine, flow bench, etc.) he do more harm than good. I would just stick to port matching and removing casting flaws.
A high performance fuel pump is a non-entity.
Re: Anyone think its worth having my Intake manifold ported and polished?
I know its useless when its NA, well actually, ill be happy with 4-5 extra HP but i am only considering this b/c i run Nitrous. Even if off the bottle, i will not suffer @ any power loss.
Originally posted by Xtreme5053
I don't think you'll get 4-5 HP Check it out at http://www.mobiletek.net/news.html
I am hoping the intake manifold would be a different story & create more power. I guess ill have to see what it does when i get this done.
Originally posted by Supermachoman
I think you should wait and see what kind of gains can be achieved from the variable intake from Road Beast before you decide on doing this. It may be a smarter choice.
I have an extrude hone intake manifold. Check out my dyno plot below. It basically gained a bit over 5 HP but even that is misleading. The two plots show more or less a before and after. The EH manifold mainly just moved my peak torque rpm up from ~4600->5000 rpm, which is where the HP increase came from. In terms of better acceleration, it's basically nil.
Spend your money on something better. Like the middle east intake. That'd be just $100 or so more and DOES provide a very substantial HP increase (20+ would be my guess).
Forge277
Jun 13, 2016 09:26 PM
