Electronic Motor Mounts
Searching through the forum, I noticed that the electronic motor mounts in the front and rear can leak and fry the computer unit if they rupture. I want to unplug mine and it looks like you have to remove the air intake unit to get to the plugs. I see the wires coming out of the mounts but then they disappear up under the air filter assembly. Is there any problem in just cutting the wires and taping off the ends of them? Eventually when they leak, I will replace them with the MT mounts.
When they do get old and you want to replace them, a good upgrade is energy suspension.
You will need non-electric/manual mounts for those though, but you can deal with that when the time comes.
I love this car. I bought it 3 years ago. It threw the knock sensor code & an O2 sensor code. The O2 code was from the tune up guy only hand tightening the spark plugs. When I torqued them to specs, the code went way. The knock sensor had a cracked housing, so I replaced it. Other than that, I 've only had to replace an alternator because the bearings went out at 129K on the clock. This car is great except for the ugly gold color, but I can live with that. Thanks for the help.
AaronL
Aug 8, 2020 10:31 AM
Unclejunebug
Apr 2, 2016 05:42 AM
knight_yyz
Nov 1, 2015 01:34 PM
