2012 SV amp Inst
Old May 12, 2014 | 05:46 PM
spartakimbo's Avatar
2012 SV amp Inst
i have a 2012 maxima with the bose system. i added an additional sub and amp. the only problem is that i can not find anywhere online that tells me where the remote wire off the stock amp for the bose sound system is. someone told me it was a baby blue wire going into the amp. this is not true. and everything i find online is different. what did everyone else do?? please help! can someone give me a definite answer?
Old May 12, 2014 | 06:38 PM
escblads's Avatar
I used this when I installed mine, there's no updated AV service manual so it should also match what's in your car.
http://boredmder.com/FSMs/Nissan/Maxima/2010/AV.pdf
You have at least 3 places to choose from, on the brown connector to the Bose amp the SB(Slight Blue?) wire (pin 20) [page 143]. Or the 20-pin white connector on the speaker amp you can use either the Blue/Pink wire or the Violet/Yellow wire [page 140]
Old May 13, 2014 | 09:54 AM
ok, according to the diagram, i had the right wire. why wouldn't it work if i spliced it in? i may have to tap into the head unit since i don't understand why it wouldn't work at the bose amp.
Old May 13, 2014 | 12:19 PM
MaximaDrvr's Avatar
I am going to assume you have a multimeter.
Just check for 12 volts with the car on and off. Find the switch wire, and use it.
Old May 13, 2014 | 03:32 PM
2012maximaS's Avatar
How are you splicing it in? If you are using something similar to T-taps, they may not work well. I tried splicing into some wires for my spoiler using t-taps at first and they didn't work at all.
Old May 13, 2014 | 04:48 PM
i do have a multi meter and no t-taps. i stripped the wires and crimped them together. I'm getting constant power to both wires i want to use. I'm thinking i may have to o thru the head unit
Old May 13, 2014 | 05:13 PM
escblads's Avatar
Constant? Can't be, you should at least have the option of the ACC wire for the radio or the AMP ON wire to turn on the amp. Which harness are you tapping into, the Brown connector to the Bose amp or a White 20-pin connector?
Also if you can't find an accessory on those, then there's always the satellite radio harness [B111] and the bluetooth control module harness [B131] which also have accessories to tap into. I don't have the Bose system but do you know if it has a delayed turn off feature until after a certain amount of time after the car is turned off?
Old May 14, 2014 | 10:40 AM
i used the brown connector going into the amp. and it does not shut off by itself. i looked for a min. also i looked online and can't find anything that says it will go off after a certain time. ill look into the bluetooth module
Old May 15, 2014 | 05:48 PM
bigmike8771's Avatar
which bose radio do you have??? monochrome(orange) screen or tech pkg with backup camera?? i just did mine a few weeks ago all connections were from the amp in the trunk. tapped all four signals from the radio before the amp, also there is a remote wire, and power wire for the bose amp u can use...
[URL=http://s73.photobucket.com/user/deem8771/media/west%20orange%20meet%207-8-06/max%20sv/photo1.jpg.html]
the red wires are all from the radio BEFORE going into the amp, the blue n white wire, are the power n remote BEFORE the amp too...
i have a 2011 sv, with tech pkg...
Old May 15, 2014 | 06:03 PM
pgs 309, 310, 311 will give u the answers your looking for... thats what i used...
the remote is pin no 20.. the power is pin no 11
Old May 15, 2014 | 10:17 PM
i have the one with the tech package as well. so it has the back up camera. when i used pin 20, it was getting constant power even when the car was off. as well as pin 11. it blew my mind. i had no idea why. i ended up going into the AV unit and splicing into the remote wire in there. it took me about an hour. i appreciate everyones input!! i spliced into a yellow and violet acc wire.
Last edited by spartakimbo; May 15, 2014 at 10:25 PM. Reason: found reset on another thread for airbag issue:)
BobTX10
Oct 7, 2015 08:43 AM
09maxshawn11
Sep 30, 2015 10:28 AM
sliptap
Sep 30, 2015 05:57 AM
jds22
Sep 29, 2015 02:03 PM
Redfox
Sep 28, 2015 10:41 AM
