Front Sway Bar Removal/Replacement
I'm fairly certain I recall a how-to thread with pictures which discussed this, but I am having trouble finding it and wanted to review it.
Most of the search results I've come across so far pertain to the sway bar end links, ES sway bar bushings or RSB.
I imagine the job may be similar to removing the power steering rack (drop y-pipe, remove cross member & front/rear motor mounts).
The reason I am looking for this is there are some isolated rust issues with my sway bar that are causing incorrect bushing fitment/reduced life. This could be solved with a junkyard replacement depending on the scope of the project.
I dont recall dropping the crossmember or ypipe before removing the sway bar when I did my steering rack(i did later however, to do the rest of the steering rack job). I just twisted and pulled the sway bar around til it came out; Although it would be easier to do so first.
Thanks for the feedback PowerTotheMax
lowpost99
Oct 26, 2025 06:53 PM
adamgalazka
Feb 5, 2023 08:24 AM
