I think I Finally "Trained" My CVT?
I I've been using Manual/Sport Mode pretty consistently for about two weeks now and driving the **** out of the thing to be honest....downshifting, jumping it to 4500-5000 RPMs before clicking up etc.
So I finally noticed last night in hitting some country roads that I was shifting and as soon as I flipped to standard D Mode and floored it to "the button" the RPMs went straight to redlining as quickly as they could and would stay there until I let off....this and the throttle response was insane! Upon further playing I noticed that when flooring it would go to redlining but when I let off and reapply gas it mimics a hard shift to the next "gear". The response and rev on the car now seems crazy....almost too crazy though. Has anyone else experienced this?
Yes, i have definitely noticed that the CVT learns your driving style but its short term memory and you have to retrain it constantly. Try this... Just cruise at around 30mph and press the gas pedal 3/4 of the way down. Then let go and repeat. I've noticed that the first time i do this, i don't get much of a response and its laggy, the next time, it improves and the rpm's shoot up faster, and by the third time its almost instant throttle response. BTW... have you noticed any CVT whining noise when driving it hard? I feel like when i use manual or sport mode and my rpm's are consistently 4-5k, i hear the whining noise within a minute or two. I've had this happen when the car was new and i thought this was normal but i may just bring this up with the dealer.
I wouldn't be surprised if the transmission learned your driving style. My old Buick had it, although not a CVT, but it would respond and behave differently just as you described after driving aggressively or passively and that was from a Buick. I'm actually disappointed if the transmission has to be relearned constantly, considering that it should have a linear learning curve per say after a hundred miles to adjust to how you been driving.
I feel like the CVT has a fuel efficiency bias so given the opportunity it will try its best to be more fuel efficient. If you don't drive it hard consistently the CVT will quickly revert back to a more fuel efficient setting and reduce RPM's and throttle response.
I think Nissan should have put a separate Sport mode button that enabled quicker response, holding of higher revs, increase engine braking, etc. All of that without the faux gear shifts from moving the shifter to DS or Manual mode. Just a separate good old button, in conjunction with the manual shifter.
On the same note, nice find! I've been actively monitoring my driving and fuel efficiency and how the car responds since this is my first CVT car.
I think Nissan should have put a separate Sport mode button that enabled quicker response, holding of higher revs, increase engine braking, etc. All of that without the faux gear shifts from moving the shifter to DS or Manual mode. Just a separate good old button, in conjunction with the manual shifter. On the same note, nice find!
maxima297
Sep 30, 2015 03:32 PM
