Trouble with my Bose/Nav system
Hi everyone Im new here hoping I can get a little help. I have a 2006 Maxima SE with a Bose system in it with the Nav All of a sudden the the radio started going on and off whenever a bump is hit, I checked all connections all seem ok since there all factory plugs I'm really not sure what the problem could be any help would be greatly appreciated.
Thank you,
Rich287
Thank you,
Rich287
that's the sound of a loose connection. I recommend turning the car off and checking all the wires for tears and loose connections. Then if all looks good, start the car and wiggle wires till you find the bundle causing the problem. Then tighten it all up. Could also be the fuse not inserted all the way in. Good luck keep us updated on the problem and solution if you find one.
