My 1st visit to a Nissan dealer
I bought my 2012 a few months ago from a used car lot.
Car tested out tight and does run well.
Used car dealer did OLF and minor maintenance prior to picking it up.
It has 74,000 km on it now.
Due for maintenance so I thought I'd go to dealer for their maintenance check and OLF.
Had them check for an oil leak, they said it was rustproofing material from previous. I had used car guys rustproof.
Also had them check loose driver seat and mirror turn signals not functioning.
They charged me $105.00 to tell me that the seat rocked and the mirror signals don't work.
WTF!!!
Cost to replace seat frame would be $1,525.00
Mirrors would be $1,115.00
I guess I'll be driving around with a slightly loose feeling seat and non functioning mirror signals.
Other than those items the car is in excellent shape.
Is there a fix for the seat like adding a washer and tightening the seat mount bolts?
WTF!!!
for the seat, I have heard that some people have used a slightly 'hill billy' method to deal with the problem - they raise the seat up, place a piece of wood under the metal frame, lower the seat down. This crushes the wood down enough to place the metal seat frame under some tension and voila, the seat is solid. Well this won't work if you need the car to accommodate drivers of different leg lengths (you can't adjust the position back and forth anymore)...but it is cheap.
The turn signal mirrors, well e-bay is your friend.
WTF!!!
WTF!!!
I forgot to mention that the inspection included a free alignment and tire check.
I just had an alignment and brand new Michelin X Ice 3 tires installed 3 days ago.
The Nissan dealer told me that the alignment was a little off and that the tires were 83% good.
I told them the tires had better be 100% as they were supposed to be brand new 3 days ago and that their alignment system must be a little off.
The advisor just shrugged, not knowing what to say.
I'll be going to my favourite independent garage from now on.
MAXSE5SPD
Sep 17, 2022 04:00 AM
MaxLife17
Jun 27, 2019 01:37 PM
Justin Kroll
Sep 2, 2015 11:06 AM
