Just got my Courtesy Strut Bar
Hey all.. I just recieved my Nissan Courtesy Strut bar..
It Says it fits a 1999-2002.. anyways mY car is the 2002 ...
and it seems as if when i put it on.. not installing it though.. I was just laying the brackets over the bolts and when i place them there.. one side seems to stick up.. or when i push the other side down the other side goes up.. does this mean this strut bar is too small? or what please help....
Re: Just got my Courtesy Strut Bar
You can adjust the bar by unscrewing it before you put it on. If you go to courtesyparts.com and find the 2k2 FSTB, there is a link for the instructions for mounting it. Good Luck. Oh yeah, make sure to torque it down to 35lbs.
Re: Re: Just got my Courtesy Strut Bar
Re: Re: Re: Just got my Courtesy Strut Bar
Originally posted by costcowholesale
isn't 35lb ft a little too light for bolts that big?
Re: Re: Re: Re: Just got my Courtesy Strut Bar
Originally posted by Bman
No, that's right. There's actually a range of torque settings for those bolts, which is 30-40 ft-lbs, so everyone just recommends 35 as a nice median.
Originally posted by dba1999us
i thought the 4th generation bar requires cutting to be able to installed on a 5th generation???
Re: Re: Re: Re: Re: Just got my Courtesy Strut Bar
Originally posted by emax95
As stated in my Nissan ECM : 43-51 lb's. Courtesy just say's 35 lb's becuase they don't want someone to take a risk.
My FSM reads: 39-54 (4.0-5.5, 29-40) <---last numbers are ft-lbs range for me, hence the 35ft-lbs average
Re: Re: Re: Re: Re: Re: Just got my Courtesy Strut Bar
Uh oh! Because we have different generations, the numbers are a bit different, but they should be similar - BUT, the first set of numbers is in Newtons/Meter(N.m), and in brackets goes kg-m, and THEN LAST ft-lbs! I hope you haven't been tightening everything in N.m's... I almost did that myself!
Re: Re: Re: Re: Re: Re: Re: Just got my Courtesy Strut Bar
Originally posted by 20 MAXIMA 02
young and ingnorant 17 y/o here.. lol.. what exactly is ft/lb on a strut bar.. cuz i kno torque is measured in ft/lb but is ft/lb a measurement of tightness? if so, what measures it? and how does it work?
It basically measures how much force you should use on the bolt when tightening it. Special(well not that special) tool called torque wrench is used. It can be had any place that sells tools starting at about $15. Or maybe folks at autozone will let you borrow it.
[QUOTE]Originally posted by Bman
Very basically, torque is "twisting force". So when you're done tightening the nuts there's no longer any torque acting on them, but it's just a way to judge how much to tighten them.
[/QUOTE
whatever u say. what r u doing here, with your 92,,anyway
[/QUOTEwhatever u say. what r u doing here, with your 92,,anyway
whatever u say. what r u doing here, with your 92,,anyway [/B][/QUOTE]
OH OH I know this one.
The very same FSTB that fits on your beautiful 2-2k Max also happens to be the only bar that fits on a 92-94 VE Max. Bman through trial and error figured this out and became a folk legend for VE owners everywhere. And they lived happily ever after. The end.
MaxLvr21
Oct 17, 2015 12:11 PM
maxima-junky
Oct 7, 2015 06:13 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
