Frozen calipers
Old Mar 13, 2015 | 08:09 PM
90KYmax's Avatar
Frozen calipers
My 90 Max VG has been parked for 3 yrs. and recently decided to bring it back to life. Started and runs fine. All 4 calipers are dragging and won't release. Repair or replace calipers? Suggestions ?
Old Mar 14, 2015 | 12:53 PM
TonyJr's Avatar
Depending on your budget. But i would go with a ebay drilled slotted rotors n brake pads for under $125. And try a junkyard to find used calipers if not ebay has them for like $50 each rebuilt
Old Mar 14, 2015 | 08:43 PM
MrGone's Avatar
Depends on the price. I mostly replace them, but I've rebuilt a few. If the rotors are worn I'd just go with a regular blank rotor IMHO.
Old Mar 14, 2015 | 10:35 PM
90KYmax's Avatar
I may take one apart and clean/ lube it and see what happens. If it takes too much time I may just buy some rebuilt ones. New rotors and flush the brake lines and new tires are next. Since my daily ride is a M45, I haven't driven the Max in awhile. Sitting for that long hasn't been good for it.
Old Mar 15, 2015 | 08:41 AM
CMax03's Avatar
At least pull them apart and see if the pitting and corrosion is too severe too rebuild....personally sometimes rebuilding them is only gonna be a temporary band aid and sometimes it's just more economical too get rebuilt calipers and use your worn out units as cores...
Old Mar 15, 2015 | 09:21 AM
DennisMik's Avatar
Is it the pistons that are frozen or the guide pins that the brake pad holder rides on?
Old Mar 15, 2015 | 10:15 AM
James92SE's Avatar
2 VE's are better than one!
Rock Auto has one of the front calipers for $19 right now, no core charge
Rebuilt front calipers can be had for ~$40 ($25 after core) WITH caliper bracket
Being that cheap I have never even bothered to try to rebuild a caliper on these cars.
The rears are more expensive but if you hunt around online you can find the rears for about $50 after core
Old Mar 17, 2015 | 09:36 AM
90KYmax's Avatar
Thanks guys! I'll let you know what condition they are in. Hopefully this weekend.
Apr 16, 2020 05:15 AM
imported_Nismo_max
Sep 21, 2015 07:24 PM
Bonka
Sep 14, 2015 11:18 PM
bbsitum
Sep 11, 2015 04:55 PM
beerman1378
Sep 8, 2015 02:19 PM
