how is forced induction even possible...
Old Apr 7, 2015 | 10:54 PM
cdoublejj's Avatar
how is forced induction even possible!? Half the engine bays requires or runs on vacuum, hard to have a vacuum on the intake when a blow is pressuring it positive 8 lbs!
Old Apr 8, 2015 | 05:03 AM
CMax03's Avatar
There are OEM inducted Cars as well ... and 100% of it's time isn't under boost especially turbo cars. At lower rpms there's really no boost....but I would highly recommend you get a book titled "Maximum Boost" by Corky Bell....Here's the book:
http://www.volkspage.net/technik/04/maximum_boost.pdf
Old Apr 8, 2015 | 06:38 AM
DanNY's Avatar
Ad·min·is·tra·tor
what cmax said.
when you're not deep in the throttle/rpm it's not in boost hence natural tendency to be in vac.
Old Apr 8, 2015 | 06:56 PM
cdoublejj's Avatar
Originally Posted by DanNY
what cmax said.
what keeps it from whacking out once under boost?
Old Apr 8, 2015 | 07:55 PM
James92SE's Avatar
2 VE's are better than one!
It's only in boost for 2-3 seconds at a time. 99% of the time driving around you are in vacuum unless you're being a total ricer everywhere you go.
What do you mean "whacking out" anyway? There are these fancy inventions called "one way check valves" to prevent your crankcase etc from seeing boost. Your power brake booster already comes with one from the factory.
Besides, it's not like you're going to slam on your brakes while actively flooring the gas pedal/keeping it boost simultaneously.
Old Apr 8, 2015 | 08:29 PM
cdoublejj's Avatar
During the Silver State challenge you can run speed of 90 MPH and up for 90 miles of public highway ...legally. also if you tracking the car i suppose.
i guess your right about check valves, that's probably a big reason why vacuum depending devices are getting pressure instead of vacuum but, if it's on boost for extended periods of time that would at least mean no vacuum or pressure, just nothing.
also i'm gonna check out that book.
Old Apr 9, 2015 | 07:47 AM
CMax03's Avatar
I was thinking the same thing to tell him...that's funny!
Old Apr 9, 2015 | 07:54 AM
CMax03's Avatar
You mean "0 psi" or "0 in/hg" ???? Impossible, I've never seen that for extended period of time it might pass thru 0 but not stay there! Get that "Maximum Boost" pdf and read it please...it'll answer alot of your questions...Get some theory and get some boost and you'll be an addict for life!
Old Apr 9, 2015 | 10:28 AM
DanNY's Avatar
Ad·min·is·tra·tor
wait...you mean you guys don't do that?
Old Apr 9, 2015 | 04:51 PM
MrGone's Avatar
check valves keep the air flowing in the right direction and vacuum canisters keep enough of it around so they can operate. 3rd gens even came with them from the factory on the intake power valve because they tend to operate under lower vacuum conditions.
The real challenge comes in running tight LSA cams and not generating enough vacuum in the first place
Old Apr 9, 2015 | 05:12 PM
MrGone's Avatar
I've had them stay at 0in/hg for 10 minutes or so in the past, but we have decent mountain passes around here
James92SE
142
Jan 2, 2024 09:23 AM
A32goldylocks
Sep 2, 2015 06:39 AM
FlaMark
25
Aug 28, 2015 10:15 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
FanaticMadMax
Aug 10, 2015 08:55 PM
