2016 Maxima SL rear seating area rattle.
My new Maxima only has 129 miles on it and has a rattle in the rest seating area. Maybe from area just behind rear seat head rests. Any ideas for cause or personal experience?
There have been times in the past when my 'parcel shelf' (the area just behind the back seats) rattled. Once a speaker was loose. Once the high mounted brake light was vibrating against the rear window.
I will be very surprised if you can find the source of this rattle without another person involved; one to drive and one to sit in the back and handle everything until the source of the rattle is found. I rode in the trunk once to help a friend find a rattle - best not to do that on public roads.
Mine just started
Mine just started rattling 2 days ago, very annoying, it's going in for a front bumper alignment rocker panel re alignment passenger mirror replacement driver seat bladder issue. I'm up my service advisors *** I've owned to many nissans and I expect better fit issues than this!!
Wanted to revive this thread. I have a rattle on the rear deck behind back seat headrests. I believe it has something to do when the rear sunshade is up. Curious if anyone else's experiencing this, and if you had this fixed?
Rattling
Noises
My 2016 Maxima SR has an annoying loud clicking noise in cold temperatures coming from the back end when I go over bumps and cracks in the road. It also has the rattle coming from the back window shelf area. The speakers also rattle in the driver door panel and back shelf on songs with a little more bass than average songs.
My dealership is looking into the back window shelf are noise today, but couldn't replicate the clicking noise this time around. They do have another SR in the shop with two of the same noises and are working with Nissan Corporate techs on the clicking sound. I really like my Maxima, but the noises are driving me crazy!!
I got the same exact noises listed above! ugh. Driving me nuts. Report back.
I had this rattle from the rear deck knocking on the rear window because of the bass. My solution was to put a few strips of foam insulation used for doors and windows on both sides. Rattle is gone now and music sounds so much better. insulation can be bought at Home Depot or any hardware store.
Marc
annoying click
The colder weather has arrived and my 2016 Maxima SR has the clicking noise coming from somewhere towards the back of the vehicle. The click occurs from normal road conditions, but little bumps or cracks in the road. It happens anytime it's below 55 degrees and gets louder and more frequent as the temperature drops. I noticed yesterday, the click is louder when the backseats have been laid flat.
I am hoping now that the cars have been our for a while, someone else may have the same issue with an answer. It is such an annoying noise!!
Click click click
I hear a click when I go over bumps near the middle console or front dash. Can't tell. It only does it when the car has warmed up. Can't stand it but don't want the dealer to disassemble everything and make things worse or create another problem.
FWIW, I have the same rear deck rattle as others here (on my 2016 Maxima SR), AND, even more annoying, is a cold weather "clicking" coming from the area of where the front dashboard meets the drivers side door. Have had the dealer look at this several times and finally they ordered a new piece of trim, yet to be installed. I am not optimistic, but we'll see what happens afterwards.
I decided to wait until a service bulletin come up from Nissan or some Maxima owner find the exact source of the clicks & cracks .
2017 sr same problem
i have 2017 sr and have a same problem. it only rattles when hitting bump or potholes.
this is a 40 grand dollar car and little thing like this really annoys me.
i'm calling nissan to arrange check up soon.
hopefully it's the spare tire case as mentioned above.
Please let me know! The tightening of the spare tire actually DIDN'T fix it as I first thought. This is so obnoxious on a $40k car.
went to dealership today. Turns out its the rear speaker that was loose. They retorqued the speakers. I drove 10 miles after the fix. No more thudding noise. Hooray
Jan. 2017...still working on a fix for this noise. It has been isolated to the links associated with the rear shocks. There has been a redesigned bolt that appeared to fix the issue for about 2 weeks. The noise is back. My service department has been amazing to work with and are working hard with Nissan to get an answer.
SR Maxima noises
If you are hearing noises from the back end of any of your 2016 Maxima's, check all of the following items: Is your spare tire centered and screwed down tightly? Is the brake light hitting against the rear window? Are the rear speakers installed securely? Does the rear shelf need some foam padding to keep it from rattling? Does the rear side trim along the back windows need to be replaced because they are loose? All of these things needed to be done to my 2016 SR and we are finally noise free!
the noise is back. Uhhhh
so frustrated. This is a 40 grand car with several minor defects.
Im heading back to the service center. This may well be due to rear shock issue.
I will keep you posted
I hope you get yours fixed. Be sure to tighten the spare tire, too!
I am having this same issue with my 2017 Platinum that only has 2800 miles on it and I have been hearing it since the first week when I bought it on December 19th of 2016. I will look at the places people pointed out and see if I can find it. I really do not want to have to go to the dealership for this unless I have too.
