timing belt replacement
Old Sep 4, 2015 | 02:42 PM
markevans999's Avatar
1994 maxima GXE 116K miles. 64k on timing belt. do i need to replace belt now or can i wait longer.
i know the recommendation is 60 k miles.
my mechanic recommends changing the belt on my toyota camry every 90-100k miles.
i do not work on the maxima myself.
Old Sep 4, 2015 | 02:52 PM
vernk's Avatar
I would do it now, yes they have been known to hold out for a long time, but if it does go you are looking at replacing head and pistons maybe whole motor depending on speed of engine when it goes...... be sure to do the water pump while you are in there.....
Old Sep 6, 2015 | 05:50 PM
Maxpwer's Avatar
No turbo, no care!
Originally Posted by markevans999
1994 maxima GXE 116K miles. 64k on timing belt. do i need to replace belt now or can i wait longer. i know the recommendation is 60 k miles. my mechanic recommends changing the belt on my toyota camry every 90-100k miles. i do not work on the maxima myself.
The 94 and late 93 had a design change from square tooth timing belts (60K) to the round tooth belts (105K). If someone really did change your belt early and you know it has 64K on it then you have about 41K miles left. You're fine.
Old Sep 7, 2015 | 06:02 AM
Tiniform's Avatar
Yep, maxpower is correct, 94 has round teeth and gets change about a 100k. To be safe, i would be looking to do it at about 90k. Water pump is external no need to worry about it.
Old Sep 7, 2015 | 03:37 PM
car was recalled with 52k miles on it. dealer recommended changing timing belt then because all i had to pay for was the belt. why would the dealer recommend changing the belt if it was good for over a 100k miles?
Old Sep 8, 2015 | 11:24 AM
chrome91's Avatar
rubber cracks over time, timing belts are recommended to be replaced every 7 years regardless of mileage due to age cracks making the belt prone to breaking
Old Sep 8, 2015 | 07:54 PM
Maxpwer's Avatar
No turbo, no care!
I don't know what the recall was for but they must have had to take the timing covers off if they only charged you for the belt. Frankly anytime you have to do all that work, you might as well spend the extra $50/10 minutes to replace the belt and tensioner. 90% of the job is just getting to all those stupid bolts on those covers with virtually no clearance between the fender.
It's true, they do say that. However I didn't change the timing belt on my 2001 Nissan Quest (same belt) until earlier this year (14 years 133K) and the same with my 2001 Toyota Camry (14 years, 92K, belt was supposed to be replaced at 90K). With 90-105k belts these days it's more likely that belt will reach its "rated age" long before its mileage rating. Ive never heard of a belt breaking before its rated miles, but I suppose it's possible. Gotta be one in a million.
Old Sep 9, 2015 | 05:12 PM
GRNMAXDMON's Avatar
Unless you like doing the job twice. Once you do the belt just replace the water pump as well. Why aggravate yourself on doing the same job more than once?
Old Oct 25, 2015 | 08:27 AM
khakuda's Avatar
I did the water pump and timing belt at 90k and at 105k, the thermostat went and was stuck open so the car never warmed up in the winter and got crap mileage. The OEM Nissan thermostat was only around $21 from the dealer. Do the thermostat, too.
Hondarydr
Dec 30, 2024 06:15 PM
PH98I30
19
Jun 13, 2016 02:38 PM
stromm
Aug 27, 2015 04:13 PM
erictown
Aug 20, 2015 08:01 AM
Maxima2010 Prem
Aug 13, 2015 11:34 AM
