Best Coil Packs
Old Sep 10, 2015 | 01:59 PM
PH98I30's Avatar
Best Coil Packs
I am headed to the JY tomorrow and want to pull some rear coil packs. Besides Hanshin, which are the best brands to get? I've got a set fronts, all Hanshin.
Old Sep 10, 2015 | 02:10 PM
JvG's Avatar
JvG
Hitachi
Old Sep 10, 2015 | 04:17 PM
JvG's Avatar
JvG
Originally Posted by JvG
Hitachi
The front injectors are the same as the back ones. The front ones are easy to get to while the rear ones are buried under the manifold.
Please look out for cracked pintile caps. Several companies will clean and test the injectors and install new caps and o_rings. I paid 18 bucks each. My fuel mileage improved, the engine has more power, and emissions have decreased.
Old Sep 10, 2015 | 04:50 PM
Turbobink's Avatar
This is NOT true ... This is apparently dependent upon your build date.
From the factory (Japanese origin) my (1999 SE-L) front three coil packs are/were Hitachi. My rear three were Hanshin.
Nonetheless, if you're able to acquire full sets of either branding, you're totally good to go IMO.
Old Sep 10, 2015 | 05:21 PM
Junebug1701's Avatar
How did we go from talking about coils to talking about injectors?
Old Sep 10, 2015 | 05:43 PM
Maxima 97 SE's Avatar
Mitsubishi are the best coil packs made for the 95-99 4th gen nissan maxima. These coil packs lasted a very long time and rarely failed. These coil packs also gave the smoothest and quietest idle with no vibations at idle. The hanshin had a recall on them on the 99 model becuase they failed at less than 50,000 miles and nissan had replaced them instead with mitsubishi coils. But its really rare that you will find any mitsubishi coils because nissan does not sell them anymore as they only sell hanshin. Plus the Mitsubishi coils have a much better spark plug boot which insulates the plug way better than the hanshin. Search on the forum by typing hanshin vs mitsubishi and you will find threads that say mitsubishi's are the best.
Old Sep 10, 2015 | 07:53 PM
JvG's Avatar
JvG
Because I'm having one of those senior moments..... sorry about that.
Old Sep 10, 2015 | 10:13 PM
PH98I30's Avatar
Looks like I'm after Hitachi or Mitsu's. Thanks for advice.
Old Sep 11, 2015 | 03:56 AM
nissan99's Avatar
On my 99 the coils in the back are longer and the front are shorter .. Always get the factory ones from the boneyard for best results
Old Sep 11, 2015 | 08:03 AM
PH98I30's Avatar
That was sort of the question. Which were OEM? My car came with Hanshin but others have Hanshin or Mitsubishi or Hitachi. I guess any of those will do. All my coil packs are original with the car and have 146K on them. I want some spares in case of failure. Yes, the fronts are shorter than the back ones.
Old May 2, 2016 | 07:56 AM
jmw8's Avatar
99 maxima coils
Is there any way of telling what brand the coils are?
Old May 2, 2016 | 07:29 PM
max ride 41's Avatar
it's written on the coil pack, the fronts are considered left, and the rears are considered right. different part number as well. hitachi is the oem for all 6 coils on my 95.
Old May 4, 2016 | 01:42 PM
TheGroceryGetter_A32's Avatar
I have a set of Mitsubishi coil packs in the classified section. Cheers.
Old Feb 20, 2019 | 04:32 AM
someguy96maxima's Avatar
Mitsubishi, Hanshin, Hitachi, Denso, Beck/Arnley ; in that order, IMO.
Old Mar 4, 2019 | 08:34 PM
CMax03's Avatar
I'm going to try NGK coil packs really soon
Old Mar 6, 2019 | 03:51 PM
PH98I30's Avatar
Let us know how the NGK coil packs work out.
Old Nov 16, 2019 | 02:31 PM
Daniel Gasca's Avatar
How did they do?
How did those NGK packs work for you? Thought about buying a set.
Old Jan 30, 2020 | 04:32 PM
wess155's Avatar
Did you ever try NGK or go with another brand?
Old Jan 30, 2020 | 08:19 PM
JvG's Avatar
JvG
Just buy the recommended brand's which are known to work well in our cars.
Old Mar 25, 2020 | 11:26 AM
1999i30t's Avatar
Anyone ever use spectra premium coil packs? They are a top seller on rockauto. I will go with hitachi if no one has any experience. I just saw the heart by there ones. C520 and c518 @rockauto.
Old Mar 25, 2020 | 03:44 PM
JvG's Avatar
JvG
The recommended ones are
Mitsubishi
Hanson
Hitachi.
multiplexor
Sep 22, 2004 01:08 PM
izzydig
Feb 26, 2004 10:18 PM
