Can I replace fuel filter?
Old Sep 14, 2015 | 11:37 PM
bumpypickle's Avatar
So I have my stock intake, iacv, and throttle body off of my 97 5mt because I'm cleaning them all. I plan on doing the egr valve, temp sensor, pcv valve and sparkplugs while everything is out, but right now those three parts are off my engine. I ordered a puralator fuel filter and didn't expect to get it this fast and already have these parts off my car so it would be nice to be able to change that while they're all off.
My question is, with those parts off (stock air box, iacv,throttle body, &corresponding electircal connectors/coolant hose, can I safely remove the fuel pump fuse and relieve fuel pressure to change out the fuel filter w/o damaging anything? The last time I changed a fuel filter on my 97 auto, I believe those said parts were attatched, well at least the iacv and throtle body that is.
Old Sep 15, 2015 | 05:04 AM
Turbobink's Avatar
In reality I'm thinking you can, but I'm also thinking of a few reasons why you shouldn't.
If it were me, I'd wait until things got put back together.
Old Sep 15, 2015 | 10:35 AM
M in KC's Avatar
Ahh, put two hemostats on the flexible fuel hose and replace the filter. You should have a pretty straight shot at it with all that removed. I've never pulled the fuel pump fuse and bled the pressure off the system when I've changed mine. You're gonna dribble a small amount of fuel out of the filter either way.
Old Sep 15, 2015 | 02:09 PM
Half Assed's Avatar
It's going to leak whether you pull the fuse or not. I'd be more worried about getting fuel shot in my eyes than all over the engine bay. It will easier to access with those parts removed and the fuel spray will evaporate by the time you get the other stuff back on.
Old Sep 15, 2015 | 04:26 PM
Daniel VQ30life's Avatar
No need to remove fuse, gas losses will be unnoticeable, not even an 8 oz glass will leak out, but now is a good time to do it, its not exactly fun with everything in the way
Old Sep 15, 2015 | 08:49 PM
ef9's Avatar
ef9
I prefer to pull the fuse and run the car till it dies. I had fuel spray in my face when doing otherwise.
Old Sep 15, 2015 | 09:27 PM
I wouldn't worry about pulling the fuse. I've pulled the fuse and not pulled the fuse...the difference is negligible if the car has sat for a while.
Old Sep 16, 2015 | 06:59 AM
cashoit's Avatar
i wdnt start the car the with all those parts removed. just drain the fuel to a bucket if anything.
Old Sep 18, 2015 | 07:05 PM
Thanks for the reply guys I know how to relieve fuel pressure just wanted to know if it's safe to do it with intake off.
Old Sep 19, 2015 | 06:28 PM
You didn't remove the lower hose first?
Old Sep 20, 2015 | 08:22 AM
maximaham's Avatar
man just wrap it with towels pull the hoses replace and be done with.
00MAXI
Sep 2, 2015 10:23 AM
305head
Aug 26, 2015 09:03 PM
homewrecker
Aug 24, 2015 08:56 PM
kirkhilles
Aug 8, 2015 10:53 AM
maxima297
Aug 3, 2015 12:50 PM
