Knocking sound when turning????
Old Jan 27, 2002 | 01:59 PM
The_Bomb's Avatar
When I turn left, like when getting on or off the interstate, there is a quick knocking sound coming from what I can tell to be my front drivers side wheel. I feel a slight movement in the steering wheel also. I have checked the lugs and they are tight, is this a serious problem that I need to have fixed ASAP? Can this be used as an exscuse to get a new suspension? BTW. this is the stock suspension with 110500 miles on it. Thanks for the help.
Adam
Old Jan 27, 2002 | 02:15 PM
guitaraus's Avatar
CV Joint?
Old Jan 27, 2002 | 02:50 PM
hooktup98SE's Avatar
Re: Knocking sound when turning????
..........absolutely...
Old Jan 27, 2002 | 04:33 PM
bullseye's Avatar
Uh-oh... It sounds like your CV Joint is bad. The rubber boot cracks and splits first. Then the grease spews out. Then dirt, grit, & sand gets to the joint and causes wear. Then it starts to make a clicking sound when you turn the wheel. When you hear it clicking, it's time to get the whole CV Joint replaced. FYI, you will get a reconditioned CV Joint when you have the repair done. This is common practice, as a new CV Joint is very expensive. Only repairs done under warranty may get a new CV Joint! Some folks feel when one goes bad, the other soon will, too. In which case, you might as well do both sides to get ahead of the bubble... Good luck.
Old Jan 27, 2002 | 05:15 PM
The_Bomb's Avatar
Hey, Thanks a lot for the info. Where would I get a CV Joint and what can I expect to pay? Also is this something me and a couple of mechanic buddies could do in a backyard with a Chilton and some previous knowledge? Any more help would be great. Thanks.
Adam
Old Jan 27, 2002 | 05:28 PM
KWheelzSB's Avatar
Bad CV joint
Sounds like a textbook bad CV joint description.
http://www.motorvate.ca/ - Check out the "Driveline" link.
If you're mechanically inclined, have the right tools, a good manual & have the job well mapped out, you can do this job - just keep in mind: if you get half way through it & need professional help, your car will have to be towed to a shop.
Old Jan 27, 2002 | 05:37 PM
The_Bomb's Avatar
Re: Bad CV joint
I can't say that I am all that mechanically inclined, but I have a friend who is getting ASE certified and I figure he can help me quite a bit. I may still have this professionally done, just trying to save some money.
Adam
Old Jan 27, 2002 | 07:16 PM
garbear's Avatar
Re: Re: Bad CV joint
Adam
Just the word CV joint makes me cringe. I was on a road trip to Dallas just after christmas and my CV joint decides to go out in amarillo. I had to ditch my car and continue on to Dallas. While in Dallas I picked up a new CV joint (about $130) and on the way back I replaced the joint in a snowstorm at midnight. took about an hour and a half.... just the right one. Really sucked but I got really good at replacing CV joints. Advice: Take off the suspension. (If you do it yourself) I had just replaced both of my joints about 3000 miles before this happened. When I was putting them on I accidentally broke the right side boot. Spewing grease everywhere.... So taking off the suspension makes the change a lot easier. Also...The driver's side joint is a pain the but to get out..... Twisting and pulling seems to work the best but you can also do what is suggested and use a screw driver. (but where's the fun in that???) Anyway.... Just my 2 cents
Gary
Old Jan 28, 2002 | 01:35 PM
Zealous's Avatar
How many miles on the car. CV joints generally fail very slowly. Back in the days before I had a budget I drove-em til they were just hammering.
Also, if memory serves me, it is cheaper to replace the entire halfshaft that to do just one joint.
In my opinion it is a pain in the butt to change CV joints. A mechanic can get it up on the lift and have them changed very quickly. You on the otherhand will likely be a shadetree mechanic--rolling around on the concrete. Expect some cuts.
IMHO -- Not worth my time to do it myself (and I have changed 4 or 5 sets)
Old Jan 29, 2002 | 03:06 PM
Uniden's Avatar
I bought a 95 GLE last January and it had 94K miles. I heard the clicking sound and had the dealer (who is also a family friend) look at the CV joints. They were going to replace them but found that they were bad. I haven't had any problems with the car and it still makes the clicking sound
Old Jan 29, 2002 | 03:51 PM
Zealous's Avatar
In case anyone cares, the clicking sounds are nothing more than the bearings sliping in and out of a small grooves that develop when we drive the vehicle through turns. These bearings and bearing surfaces are not high speed (relative to bearing speeds) and therefore the chances of having a major problem due to a failure is small--usually clicking slowly gets louder until it becomes a hammering long before failure.
Old Jan 29, 2002 | 03:53 PM
The_Bomb's Avatar
I have decided to let my friend take the car into his Auto repair class here at school and the labor will be done for free all I have to pay for is parts . Oh he says he will work on my car personally and I trust him to do the job right so this all worked out well, except for havingt to buy the new part.
Adam
DJLAX152
May 4, 2021 11:46 AM
LtLeary
Sep 14, 2015 12:33 PM
ballerchris510
Sep 11, 2015 05:29 PM
