P0500 but not why you think
Old Oct 9, 2015 | 07:10 PM
Autoexec's Avatar
I have a 97 Maxima SE Manual Trans that has a P0500 code. Speedometer does not work. Weird thing is at first it would move slightly if you floored it. I replaced VSS. I replaced cluster. Twice. No change. I took cluster apart and tightened the screws and checked for broken solder joints. Nothing. I then figured out how to test the speedo off the car by wiring the VSS and power to the cluster. I then used a drill with a pinion snubber in it to turn the gear and, guess what? It worked! Speedo needle moves. Now I am thinking "It's the wiring in the car", even though I did continuity tests and all appeared fine. SO I bypassed all of the harness wiring and wired the VSS directly to the cluster with power and ground. Plugged in VSS and spun it. Works fine. Put it in the car and...NOTHING. It seems the VSS is not turning when in the transmission. I took it out and stuck my finger in the hole but I don't feel anything. No gear, no shaft, nothing. I stuck a screwdriver in there in case my finger wasn't long enough. Nothing. What the heck is going on? Has anyone heard of such a thing?
Old Oct 10, 2015 | 02:52 AM
ef9's Avatar
ef9
Interesting, and great troubleshooting.
Best bet would be to tear it apart.
Old Oct 10, 2015 | 03:49 AM
Autoexec's Avatar
I'll sell the car before I go into that trans. Just not worth the trouble.
Old Oct 10, 2015 | 11:53 AM
bumpypickle's Avatar
I have the same problems. Im hoping a gauge cluster change will fix it as the head of the bolt on the vss snapped off
Old Oct 10, 2015 | 01:58 PM
Autoexec's Avatar
Which problems? I'm confused. You can't replace the VSS so you hope the cluster is bad? You could drill and remove the broken bolt with an extractor. That would need to happen no matter what is at fault.
Old Oct 10, 2015 | 02:13 PM
The problems that relate to that trouble code. Yes I hope it is the cluster because I do not feel like removing that bolt with an extractor. Yes I know what an extractor is, I have one, but it is too tight of a spot for my interest. And if the gauge cluster is really whats wrong with it, which I believe it is because it intermittently works when tapping it, then I don't see the point of even touching the VSS.
Old Oct 10, 2015 | 02:22 PM
Autoexec's Avatar
I get that it is a pain, but you have to realize the car doesn't care. If there is nothing holding the VSS in it can work it's way out. Did you do the usual tightening of the screws on the back of the cluster?
Old Oct 10, 2015 | 02:38 PM
The bolt is seized which is why the head broke off. It ain't going anywhere lol, and yeah, I carefully took it off and tightened to no avail. I'm picking up a cluster locally from someone off CL in the next week for $20 though,so hopefully thats the issue. I could care less about the rpm gauge, although being manual it would be nice to know when im about to hit redline. I just care about the odometer
Old Oct 11, 2015 | 05:49 AM
asand1's Avatar
The bolt is seized which is why the head broke off. It isn't going anywhere lol, and yeah, I carefully took it off and tightened it to no avail. I'm picking up a cluster locally from someone off CL in the next week for $20 though,so hopefully that's the issue. I could'nt care less about the tachometer, although being manual it would be nice to know when i'm about to hit redline. I just care about the odometer
Fixed it for you. You're welcome.
Old Oct 11, 2015 | 06:13 AM
Old Oct 22, 2015 | 07:48 PM
jgreaves42's Avatar
Any further news?
I'm chasing the same issue as the OP. I ha e replaced the VSS and tried swapping out the gauge cluster. I have tightened the screws on the back of the speedo as well as resoldered the 8 connections on the back of the speedo. Are there any further steps I have missed?
Old Oct 27, 2015 | 03:55 AM
Diesel_hunter's Avatar
When i bought my maxi my speedo didnt work, replaced the sensor, still nothing. Came to realize that the wire harnesa rides up the front of the trans and i guess it gets real hot in there cause they were burnt bare, rewired it and good as new
Old Oct 29, 2015 | 05:04 AM
jgreaves42's Avatar
Nice idea
I have replaced the vss and its wiring. The gauge cluster has been swapped out twice since it was a suspect part and I'm just gonna put the original one back in and see what Nissan make of it. I have done all the checks and rechecks I can find but since I suck at wiring I'm just gonna suck it up. I will take a copy of the TSB about the harness over the engine with me and see if they can chase it down that way. Thanks for the input and I'll let you know how it all shakes out.
J
Old Oct 29, 2015 | 10:18 AM
JvG's Avatar
JvG
Jgreaves42, please let us know of the outcome once the Nissan dealer is done. Also the parts and labor charges.
Old Nov 23, 2015 | 01:35 PM
jgreaves42's Avatar
Ok here's the final verdict...
The DSPO (Dip Sh*t Previous Owner) had disconnected one of the speed sensors to the transmission! The cause of the stalling at idle has since been resolved as a break in the wiring to the IAT sensor. They are weak on the outside of the sensor where the wire pigtails to the connector. Now that that has been ordered and all transmission codes cleared the only light left is an abs sensor light for the left rear.
I hope this helps... good luck to all those chasing silly gremlins.
Professor
Aug 21, 2015 07:36 AM
Mrbizness1
Aug 18, 2015 08:43 PM
ffcbairn
Aug 16, 2015 09:29 PM
ef9
Aug 13, 2015 01:19 AM
mls277
Aug 11, 2015 07:18 PM
