Sub and Amp in 2016 Maxima question
Old Nov 12, 2015 | 08:56 PM
desertbrown27's Avatar
Hey guys I'm new on here but I am putting a 12" Subwoofer and a 1000watt amp in my maxima SL with Bose audio System. After the shop installed it I am get a ton of feedback. they have used different parts, moved the jacks, but nothing will get rid of the feedback. It will happen while idle, when I push the gas. Will stop if I open a door or put the windows down. Has anyone had this problem? Been looking online but haven't found a maxima with a bass system yet. Help
Old Feb 16, 2018 | 10:07 PM
Nissanfinatic's Avatar
Question my man what adapter did you use for the amp. I keep hearing that bose systems reject subwoofer applications.
Old Aug 9, 2018 | 08:48 PM
JEstrada97's Avatar
Hey guys I had the same problem and came across this video on Youtube. Hope this helps..
Old Mar 11, 2019 | 02:33 PM
Daniel Jansen's Avatar
Running Power From battery
Currently trying to run power from the battery through the firewall, anyone have suggestions on what might make my life a little easier?
Old Apr 1, 2019 | 09:19 PM
MattyPeezy's Avatar
I gave up on trying to find a good way to get through the firewall and ended up running power underneath the car and coming up through the spare tire well. Pretty straight forward just make sure you secure it well with zip ties every 6-12 inches or so to keep it snug to the car and obviously don't run it too close to any moving parts or anything that gets hot and you'll be just fine. The spare tire well is good for ground too. Also, if you have the xtra wire to do so you may wanna go ahead and do 2 runs of power wire to save yourself a headache down the line if you ever need to upgrade or you add another amp or something like that. Hope this helps, please let me know how it turns out if you try this way. Good luck.
desertbrown27
Jul 16, 2020 03:19 PM
RockfordMax
Jun 23, 2006 08:08 PM
Maciek
May 30, 2004 06:03 AM
Empz
Apr 29, 2004 05:18 PM
tunedup
Feb 7, 2001 08:29 PM
