Help! Power windows don't work in 97 maxima.
Hi. An auto parts store worker installed the wrong battery with reverse charges in my 97 maxima. At the time it sparked, and ever since then I've discovered a lot of problems. I've replaced the main fusible link so the power doors now work and the radio fuse so the radio now works. I replaced a fuse under the hood for the power windows but they still aren't working. What other fuses would go to the pw? What else could be the problem? Any help is greatly appreciated. Thanks in advance!
It was definitely a hard lesson to learn. The rear window defroster also isn't working. Possibly other things too, but nothing too important. Thanks for the advice. How would I get to the bds relay?
Here's 2 more fuses for you to check.
1) under the hood by the battery, check the 7.5 amp fuse labeled BCM.
2) in the dashboard, check the 7.5 amp fuse is position # 12. Fuse # 12 is the bottom fuse in the center column.
RealityCheck
Jan 12, 2017 02:13 PM
TKHanson
Oct 19, 2015 10:50 PM
who4ever
Oct 9, 2015 05:50 PM
