downpipe flexible is dead.....new downpipe
Old Feb 12, 2016 | 11:23 AM
blanik99's Avatar
Hi
i'm new here (hi to everyone)
nearly 1 week from now my 2000 maxima GLE start to make a little deep sound....ok so i got a exhaust leak
i check under the car and the flexible after downpipe negin to fall (mesh begin to fall)
so i check over ebay and everything and dont want to put 1000$ on this car (only need this car to hold up tu 12-16 month max...lol
it'S great car with only 105k (65miles)) so i can put the effort of repairing it
i see a lot of cheap y pipe WITH headers , but have any one of you bought this but only install the downpipe (it'S winter here in canada i dont want to change headers in snow outside....just want the car to stop making sound!!!
I think that maybe the cheap y pipe from eBay can only be install with the headers (not OEM) iM i right?
or i just maybe better buy warpspeed downpipe? or other solution to check over?
it's a 2000 canadien 3.0 VQ30de i dont have the weird precat
WTF...i can'T upload any picture with URL....i'm in many forum and have no problem to post picture normally.....Something i must do wrong
Old Feb 12, 2016 | 11:29 AM
blanik99's Avatar
here is picture of my donwpipe model
(the old one :P )
also a picture under my car (flexible broken)
Attached Thumbnails downpipe flexible is dead.....new downpipe-ypipe004.jpg   downpipe flexible is dead.....new downpipe-20160212_132506.jpg
Old Feb 12, 2016 | 01:28 PM
eastsidemoon's Avatar
You should be able to get a new flexpipe for cheap at any muffler place. No need to replace the Y pipe unless you want too. I'm not sure of your exhaust diameter but you can order a flexpipe from Summit Racing http://www.summitracing.com/search/p...ibanner=SREPD1
or any exhaust place will have a replacement.
Old Feb 12, 2016 | 04:29 PM
blanik99's Avatar
With all the heat sheild around flex pipe it look difficult to weld or clamp anything.....i'll check with my local mechanical shop
Old Feb 12, 2016 | 06:42 PM
Heel Til I Die's Avatar
my exhaust rusted and separated at the flex pipe a couple years ago when I was trying to fix the separation right in front of the muffler. A local muffler shop welded everything up for $100. I would check around at some local shops unless you really just want to get a new y pipe.
Old Feb 13, 2016 | 02:00 AM
Child_uv_KoRn's Avatar
Bad *** Newb
Just rip/cut it off. Our heat shields are useless unless you like rattles.
Old Feb 13, 2016 | 07:11 AM
Itz Shak's Avatar
Old Feb 13, 2016 | 04:37 PM
maxinout93's Avatar
what is the best tool to use for cutting the heat sheilds off? seems ike mine are stuck
Old Feb 13, 2016 | 04:41 PM
maxinout93's Avatar
what is the best tool to use for cutting the heat sheilds off? seems like mine are stuck on/bolts are impossible to remove.
Old Feb 13, 2016 | 05:03 PM
Bad *** Newb
Angle grinder with cut off wheel
kirkhilles
Jan 27, 2016 06:25 AM
slickblack94
Dec 26, 2015 01:04 AM
spy code1
Dec 25, 2015 09:34 PM
Justin Kroll
Dec 17, 2015 11:27 AM
