I Keep Blowing Maf Sensors
Old Mar 14, 2016 | 10:51 AM
-ReLLiK-'s Avatar
I'm on my fourth maf sensor now.. 03 3.5 swap
The problem mainly starts if its wet out or theres a lot of moisture in the air. I initially get symptoms of hesitation, loss of power, bucking etc., then the car dies and will only crank.
Once I put another sensor in it starts right up no problem...
Anybody else have similar problem? I haven't had chance to check the maf harness yet but is there anything else I should check for???
Old Mar 14, 2016 | 01:10 PM
njmaxseltd's Avatar
If you keep replacing the same part, and the problem continues to happen over and over again, then I think it's time you start looking at something else as the cause.
The MAF sensor doesn't pick up or have the ability to read or sense moisture.
Aftermarket or stock intake?
Old Mar 14, 2016 | 02:33 PM
-ReLLiK-'s Avatar
Aftermarket intake with oil air filter. I also thought maybe this was the cause so this time I left it off and cleaned it first before I reinstall it (at work currently). Also ordered a k&n dryflow...
I seen this video that says oil filters damaging mafs is a myth? Or maybe our sensors are much more sensitive? Idk at this point...
Old Mar 14, 2016 | 02:40 PM
Fakie J Farkerton's Avatar
I've seen more than one over oiled filter cause a MAF to fry
Old Mar 14, 2016 | 06:21 PM
LJay's Avatar
Try a dry flow air filter with stock intake or even just a dry flow. It works wonders. AEM is a good brand
Old Mar 14, 2016 | 10:14 PM
BronxSleeperMax187's Avatar
You need to blow some money on A better sensor maybe.
Old Mar 14, 2016 | 11:20 PM
-ReLLiK-'s Avatar
So I switched the filter out earlier to one I had on my other car, forgot it would fit..
Drove fine no issues. I shut the car off to cool down. Tried to start, it just cranks. Wtf?? I'm startin to think my wiring harness is
Old Mar 15, 2016 | 05:23 AM
njmaxseltd's Avatar
What code is it throwing?
Old Mar 15, 2016 | 11:12 AM
5.5+ MAFs can be temperamental.
Grab a OEM 5th gen sensor and swap over your thermistor.
Old Mar 15, 2016 | 06:12 PM
-ReLLiK-'s Avatar
Just got my codes scanned and I have a p1320 ignition code. Going to grab coils..
Still running a 3.0 maf atm. I'll look into doing that thanks
Old Mar 15, 2016 | 06:36 PM
Woops! Either way, installing a 5th gen MAF sensor will allow you to run cant_get_ryte's dyno proven intake.
Old Mar 15, 2016 | 06:52 PM
JvG's Avatar
JvG
Might get more accurate replies from the 5th generation section.
Most of us still have the 3.0 engine.
Old Mar 15, 2016 | 10:05 PM
The 5th gen is A 3.0
Old Mar 19, 2016 | 11:59 AM
-ReLLiK-'s Avatar
So I think I found the problem.. Turns out I forgot I had a 3.5 oil pan and 3.5 crank sensor spliced into the harness.. Bought a 3.5 cps and so far so good
The difference in the 3.0 cps and 3.5 is the 3.5 cps is slightly longer
Thanks for the help guys!
Old Mar 20, 2016 | 01:38 PM
-ReLLiK-'s Avatar
Still blowing maf sensors. Only sensor I haven't changed was the cam sensor... When I plug a new sensor it it runs. Once the car is warm I shut it off and it won't start again...
I'm at the end of the road with this car. No issues until recently
Old Mar 20, 2016 | 06:37 PM
vqmaxman's Avatar
Is the maf sensor harness spliced opened where its exposed that can lead to having a bad maf sensor.Is the water tampering with the maf wires and harness.
Old Mar 20, 2016 | 07:51 PM
-ReLLiK-'s Avatar
Nope checked that earlier today. I even soldered in a new plug bc the old one wasn't clicking..
I'm wondering if the alternator/battery is getting hot when it runs, making the maf malfunction??
Old Mar 21, 2016 | 02:52 AM
vqmaxman's Avatar
Do you have any of the wires running from the maf to the alt/batt?
Old Mar 21, 2016 | 03:12 PM
maximaxi's Avatar
What kind of MAF are you using? What brand? The only ones worth buying are OEM, Bosch, and Beck/Arnley. The rest are Chinese garbage.
Use a regular air filter like Wix.
Old Mar 22, 2016 | 07:59 PM
-ReLLiK-'s Avatar
OEM. The eBay one I bought new lasted me a year. Been pulling oem mafs out the junkyard for now
Old Mar 22, 2016 | 08:07 PM
vqmaxman's Avatar
What gen ecu and maf you using. The ecu on 3.0 and maf have different voltage than the 3.5 iirc.
Old Mar 22, 2016 | 08:26 PM
-ReLLiK-'s Avatar
4th gen 97 ecu 4th gen maf
Cars been swapped since 2008. I bought it in 2011. Never had an issue this severe until now
Old Mar 22, 2016 | 08:37 PM
vqmaxman's Avatar
Ecu is 4th gen and maf is 4th gen. Is the motor 3.5 swap completly top and bottom. Is the harness all of a 4th gen or 5th gen. Is the fuse box completly been swaped replaced 5th gen. I am trying to pinpoint the problem. The voltage is spiting out big somewhere. The maf try 5th gen.
Old Mar 22, 2016 | 08:47 PM
-ReLLiK-'s Avatar
3.0 timing swap, 4th gen harness/fuse box
I have a 5th gen maf and plug on the way. But if I'm not mistaken, 5th gen maf has 4 wires and 4th gen has 3?
Which was my next question in finding how to wire the 5th gen maf
Old Mar 22, 2016 | 09:44 PM
vqmaxman's Avatar
The 3.0 5th gen maf i saw the diagram on the fsm it goes something like this battery------w/L to ecm relay from relay--w/b and r/g to ecm and r/g to mass connector-r-w-b.
Old Mar 23, 2016 | 09:38 PM
-ReLLiK-'s Avatar
I got the 5th gen maf and I'm looking at it, but I don't understand what you mean with the color connections
Old Mar 24, 2016 | 09:55 AM
-ReLLiK-'s Avatar
$200 later (Nissan still wants 450+) Napa maf installed. Let's see how long this lasts..
Old Mar 24, 2016 | 10:07 AM
-ReLLiK-'s Avatar
So i got about 5 miles now the car just died lol
Old Mar 25, 2016 | 08:11 PM
vqmaxman's Avatar
Giving you an idea what you should have and how you should connect the maf. Did you ground the maf and is it high or low input/output shorting the maf out.
Old Apr 1, 2016 | 03:43 PM
-ReLLiK-'s Avatar
Sorry for the late update Ive been busy. Took a break from crying myself to sleep..
Finally got around to grounding the maf sensor today. When I tested it it was out of specs. After grounding the voltage dropped significantly...
So I figured I fixed it, but then the car wouldn't start after shutting the car off...
Turns out the cam sensor was also bad. After replacing car starts and drives with no issues again.. ✌
I'll keep this post updated if I run into anymore issues (I hope not)
Anarchy
Apr 1, 2019 07:19 PM
Lowered_a33
May 21, 2016 01:08 PM
reallywildstuff
Mar 21, 2016 07:51 PM
slickblack94
Feb 29, 2016 10:33 AM
blacrob
Feb 24, 2016 08:38 AM
