tilt down sideview mirrors not going back up
Old Mar 15, 2016 | 05:59 PM
Jomil's Avatar
is this a common problem? my car's sideview mirrors tilt down when reverse but don't tilt back up when i put it in drive. should I take it to the dealer? I just got it and it was a certified pre-owned car with the extended warranty
Old Mar 15, 2016 | 07:43 PM
Richard66's Avatar
By all means take it to the dealership for the warranty work.
Old Mar 21, 2016 | 04:32 PM
Maxgig's Avatar
First try manually moving the offending mirror through all its motions then see if it works normally. I had my passenger side mirror actuator replaced 2x under warranty and the 3rd I did myself.
Fed up I moved it by hand and found that the actuator was still good. This past year I had my car in 110 degree heat of the Mojave desert and in single digit temperatures in Kansas this winter.
The common denominator I found in both extremes was that I washed my car a lot in the desert because of the dust and in Kansas because of slush and other road grime that got on it.
I sprayed some lithium grease on the moving parts and so far it's still working.
Timur Yakubov
34
Mar 15, 2021 01:04 PM
nissan99
Mar 15, 2016 11:14 AM
Vdub328
Mar 14, 2016 06:36 PM
DFry97
Mar 11, 2016 03:52 AM
BlackMaximus04
Mar 9, 2016 09:04 AM
