Hanging wire next to transmission pan?
Old Mar 24, 2016 | 10:54 AM
dcam0326's Avatar
Hey guys I'm dropping my transmission pan to inspect today and I was starting to unbolt the 21 bolts and noticed a mysterious wire hanging on the driver's side of the transmission pan. It appears to be damaged at the connector but I have no idea what it's supposed to be connected to and I'm having a hard time getting a view of where it comes from. Here's a pic:
Anyone know?
Old Mar 24, 2016 | 11:25 AM
Mattx's Avatar
Look like grounds.
Old Mar 24, 2016 | 12:17 PM
mclasser's Avatar
Are you having any issues with the car?
Old Mar 24, 2016 | 05:17 PM
maxiiiboy's Avatar
If it were brown, I would say "previous owner replaced/eliminated the rear e-mount", but it's a black connector. So, it must be one of the sensors. As the car is running fine it's hard to guess.
Old Mar 24, 2016 | 05:35 PM
Brudface's Avatar
That is FOR SURE the ground to the transmission. The other end of the connector should go to the rail about 8" forward of the mount.
Old Mar 24, 2016 | 05:36 PM
dcam0326's Avatar
Well I've been having intermittent slipping transmission issues, and occasionally the RPM's will kick up out of nowhere during slow/normal acceleration and it won't shift out of first gear. Might even be dropping a gear now that I think about it... I did the old drain and fill/cleaned the magnets today haven't driven it much yet though to see if the issue is resolved. The old fluid was brown and very dirty though, but no metal shavings in the pan just some gunk on the magnets as was expected.
What happens if it is disconnected? Sorry I'm clueless when it comes to electrical stuff. The connector itself looks to have a piece of metal (possibly the rail itself) sheared off inside of it so I don't think I can reconnect it... I can try to get a better pic tomorrow of the connector and rail itself.
Old Mar 24, 2016 | 08:36 PM
Brudface's Avatar
The transmission should technically be grounded. Which is why they sell grounding kits. I would suggest taking the wire and snipping the end of it off and connecting a ring terminal and just bolt it to the transmission.
Old Mar 25, 2016 | 07:40 AM
cdoublejj's Avatar
if you get the grounds and wiring fixed and it still does it, then look at a trans go shift kit.
Old Mar 31, 2016 | 02:55 PM
dcam0326's Avatar
Originally Posted by Mattx
Look like grounds.
Just bumping this thread to say grounding the wire worked! Transmission is smooth as butter again. Thanks guys!
Old Mar 31, 2016 | 06:44 PM
Brudface's Avatar
Figured. I would suggest getting a grounding kit by either making one yourself or purchasing it pre made. Pretty easily done yourself though tbh. Good luck and happy driving.
Old Apr 1, 2016 | 02:12 PM
5thgendriver's Avatar
who sells such kits as my radio at times has static really bad. especially when I turn on the defrosters.
Old Apr 1, 2016 | 08:34 PM
Brudface's Avatar
Stillen, Member on here Shinjudo, Ebay. It is extremely easy to do yourself though, but if you want a premade kit then they are your best options.
Also depends if you have an aftermarket radio installed. IF you do then I would take it out, reconnect the antenna adapter IF you're using one and wrap it in electrical tape to stop the interference. You could also try moving it to a different spot than where it is. First suggestion works pretty well though.
Old Apr 1, 2016 | 09:55 PM
stock radio. what's this antenna adapter?
Old Apr 2, 2016 | 11:46 AM
Brudface's Avatar
The adapter is for if you have an aftermarket radio. It allows you to connect the antenna to the aaftermarket radio. No worries if you dont have one. If you are getting distortion while using the rear defrost it could be a ground at the rear of the car as the antenna and defrost use the same ground which SHOULD be if i remember correctly either drivers side C pillar or passenger side C pillar. I really cant remember but youd have to pull of the plastic trim peices to find out.
Old Mar 2, 2017 | 10:02 AM
maxinout93's Avatar
ok I recently found that same wire disconnected on my car. The connector is damaged on the end so im gonna try the method that was suggested a few posts up and snip the wire. What happens if you leave the wire disconected?
Old Jan 31, 2023 | 12:01 PM
911 trees's Avatar
I have a 2000 Silverado and all the gears work great except for when I put it in reverse it does not engage and it is not throwing a engine warning sign or any other sign I hooked up code reader on the bottom of steering wheel and it comes back only as sensor or Cadillac converter that's the only signs that it says I did a transmission fluid flush and still I have no reverse what could be the problem
Old Feb 1, 2023 | 11:06 PM
Why would you join a Nissan Maxima forum to ask a question about a Chevy Silverado? There are plenty of Chevy forums out there.
Old Feb 7, 2023 | 07:37 AM
Prophecy99's Avatar
i reported the comment. lol
BlueMaggie
Feb 4, 2021 09:31 PM
kiyakerz
Feb 12, 2006 04:52 PM
jif718
Jul 6, 2005 09:02 AM
snair2
May 7, 2005 10:12 PM
motocross416
Mar 22, 2005 07:02 PM
