ABS problem?
Old Apr 11, 2016 | 08:05 AM
Maximusdriver's Avatar
ABS problem?
Hey,
I am having an issue with my ABS brakes on my 2000 maxima. They have worked before but now they aren't activating as well as they use too, so I am wondering if the sensor needs cleaning? Or is this another problem?
Thanks,
Maximusdriver
Old Apr 11, 2016 | 02:42 PM
MadMax SE's Avatar
When was the last time you had the brakes done, or the lines bled to the brake calipers. Air in the lines can cause squishy brakes ish feeling and i wouldnt doubt the air would mess with abs, it uses brake fuild to operate
Old Apr 12, 2016 | 05:18 AM
I don't know when the brakes were last replaced, but I do know I got the brake fluid flushed a month or two ago.
Old Apr 12, 2016 | 05:36 AM
Derrick2k2SE's Avatar
How are you testing the system?
Old Apr 12, 2016 | 05:48 AM
Slamming the brakes trying to engage the ABS. Is there another way?
Old Apr 12, 2016 | 05:52 AM
Child_uv_KoRn's Avatar
Bad *** Newb
If the wheels aren't locking up solid, then ABS is working and/or you can't break traction.
You're going to have to be specific of the symptoms.
If the pedal isn't soft and brake performance is good, then there's nothing wrong.
Are you testing in the wet?
Old Apr 12, 2016 | 05:57 AM
Ok, thanks for letting me know, my wheels haven't been locking up, so I guess I don't actually have any problems.
Old Apr 12, 2016 | 06:28 AM
Probably not. You'll feel a distinct thumping through the pedal when the ABS kicks in. Generally it either works or it doesn't. If it's not working you'll get an ABS light.
The conditions you test it in will play a role too. Even trying it on a cool morning vs. a hot afternoon will affect the traction on same road.
Old Apr 12, 2016 | 06:41 AM
Ok, I will try testing them again soon.
Old Apr 12, 2016 | 09:32 AM
MadMax SE's Avatar
Perhaps whom ever flushed the system didn't bleed the calipers in the correct order. I forgot to do the caliper order correctly and my brakes were squishy and my ABS/TCS was on all the time on a previous vehicle I owned. Brakes still worked and it was winter so I dealt with the lights.
EndoT800
Aug 28, 2018 01:34 AM
TonyJr
Jun 2, 2016 05:42 AM
xydehead
Apr 7, 2016 03:04 AM
ameerhussain57
Apr 5, 2016 07:46 PM
mrdigray
Apr 5, 2016 02:14 PM
