Cranks but won't start
Hey guys it has been a long while since I have been here but having some real problems. My 2010 murano just lost the transmission so I am down to my 2003 maxima as a family car.
2003 maxima AT 195k miles. Car cranks but will not start. It has had code p0445 (EVAP leak) for a while and the starts having been taking longer and longer. Today it finally failed to start and is showing the EVAP code along with p1800.
Is there a common solution that causes a no start before I start any diagnostics?
Thanks for any help
Thanks for any help
Thanks for any help
Thanks for any help
Try unplugging the crank sensor and see if it will start.
So I put gas in the car and it started. Idk what made me add has since the meter says I have almost 1/4 tank. But at least it started
Edit: I filled the tank and it reads under 7/8 full
not for nothing but mabye you should run an additive in the tank to possibly free the little unit that reads gas level. i read somewhere on here they can stick easily, or otherwise replace the pump. i only trust seafoam as my snake oil of choice. it has shown decent results when ive used it in the past.
Idk if I will even get a new cluster given the value of the car.
Ouch, it's always electrical with these newer cars. Anyway, if you have access to the wires, you could jury rig a voltmeter into the gas gauge lines and read resistance as you fill up. Record resistance when you fill up and when you start bucking from low gas( don't attempt without a spare gallon of gas on hand) I saw it on this video called No ***** given rx7.
illvillecat99
23
Dec 4, 2016 01:57 PM
valerit1
May 19, 2016 04:13 PM
slickblack94
Feb 29, 2016 10:33 AM
