Pathfinder Throttle Body Swap
Old Apr 14, 2016 | 09:46 AM
RadjaThat's Avatar
Hi Guys,
I just had a quick question regarding a pathfinder throttle body. I was wondering about installing one. I know an adapter plate is needed to attach the pathfinder throttle body to the stock intake manifold. My question is what about the electrical connectors, throttle cable and the coolant lines.
Thanks!
Old Apr 14, 2016 | 07:48 PM
schmellyfart's Avatar
You can use an adapter plate or I can redrill it for you so no adapter plate is needed. The intake manifold will need to be ported to match the throttle body either way. The TPS is the same, coolant lines aren't necessary to reconnect but you can if you want to, and you use your old throttle cable-however you might need to move the throttle cable bracket or make a new one.
Old Apr 15, 2016 | 05:11 PM
RadjaThat's Avatar
So should I just do an 00VI swap at this point?
Old Apr 17, 2016 | 04:12 PM
Not necessarily. You are still going to have similar issues with the 00vi, in addition to all of the other quirks of installing an 00vi.
EndoT800
Aug 28, 2018 01:34 AM
eraygoza
Apr 12, 2016 08:50 AM
css12
Apr 9, 2016 05:33 PM
NRAsteveo
Apr 7, 2016 08:33 PM
cardana24
Mar 23, 2016 12:15 PM
