Ebay turbo needs rebuild (video)
Old May 20, 2016 | 02:16 PM
TonyJr's Avatar
Old May 21, 2016 | 04:57 AM
Tiniform's Avatar
Did you buy the turbo used? It seems to have failed early even for an eBay one.
Old May 21, 2016 | 05:10 AM
James92SE's Avatar
2 VE's are better than one!
Tony how did you resist that ice cream truck!?
Old May 21, 2016 | 08:18 PM
TonyJr's Avatar
Lol
Old May 21, 2016 | 08:22 PM
TonyJr's Avatar
Never used bought off craiglist. There was no shaft play. It was solid spin, perfect condition. Shredded metal is what destroyed the journal bearing. I'm waiting on rebuild kit. I already purchase a magnetic oil drain bolt. Planning on doing 2 oil changes before installing my rebuild turbo.
Old May 21, 2016 | 09:07 PM
DanNY's Avatar
Ad·min·is·tra·tor
it's probably metal burrs from manufacturing. it's due to poor QC on building the turbo from china.
"c-clip"...that's the name of the clip. it's also known as lock ring too.
when you rebuild a turbo you're supposed to strobe light balance it. i doubt you have that equipment or the skill to do that...so just keep that in mind that it's not as easy as pulling bearing out and throwing them back in. the oil passage ways allows for the oil to come in and basically the journal bearing rides on a thin coating of oil. if you do decide to swap it out and throw it back together your turbo might live a short life. keep in mind that blade spins at like 100K RPM.
in any event i doubt you'll listen to me and you'll do what you want to do anyway...so good luck.
Old May 25, 2016 | 03:08 AM
TonyJr's Avatar
I mark it so it can stay balance. Godspeed turbos come balanced. I can see the marking. But ill wont listen to you and do want i want to do jk lol.
The godspeed turbo is going to be a backup turbo. I'm picking up a holset today and rebuild it before installibg it as my primary turbo. But just to let everyone know this EBAY TURBO godspeed is not crap, it actually works well. Stupid shredded pieces of metal from bad timing chain cause the journal bearing to wear out fast. I'm planning on doing 2 oil changes installing the magnetic oil bolt then ill install rebuild turbo
Old May 25, 2016 | 05:27 AM
ac max 92's Avatar
Are you breaking almost everything you touch these days Tony Lol
Old May 25, 2016 | 06:06 AM
DanNY's Avatar
Ad·min·is·tra·tor
ok as long as you marked it and it goes back at that same spot then you're good...for the most part.
wait...how did a piece of metal end up there? your engine picks up the oil from the screened oil pick up and send it up to the engine (through the filter of course). how did that piece of metal get by?
Old May 25, 2016 | 05:31 PM
TonyJr's Avatar
This year things are just going bad smh. Now my brakes need some attention. It's a never ending project That i enjoy
Old May 25, 2016 | 05:35 PM
TonyJr's Avatar
Good question. Tomorrow I'm doing oil change. So ill check old oil to see if i see metal flakes. I just received my magnetic oil pan screw hopefully this will answer some question.
Old May 31, 2016 | 05:37 PM
TonyJr's Avatar
Finish rebuild godspeed turbo today.
Mike H.
Sep 30, 2001 10:50 PM
freeze2k2
Aug 5, 2001 06:35 PM
teejnut
Jun 26, 2001 07:23 AM
