HID light problems
Old Sep 4, 2016 | 04:17 PM
jayfoxx357's Avatar
HID light problems
Forum noob..Long time lurker
Just took these HID's off my 95 max
I try and put em in in my 97 and these are the results I get when on regular lights and hi beams
Help
AC Ballast btw
Attached Thumbnails HID light problems-20160901_215344.jpg   HID light problems-20160901_215426.jpg
Old Sep 4, 2016 | 05:30 PM
wesmantooth1's Avatar
Could you kindly explain what is going on? You don't provide enough information in the post. I can see a yellow-ish on the driver side in first pic, then brighter in the 2nd pic. I'm assuming the 2nd pic is highs.
What's the question?
Old Sep 4, 2016 | 05:34 PM
jayfoxx357's Avatar
Pretty much how do I get both of the lights to be all one color? When I switch the high beams on they're supposed to be all blue and when they're not on the original yellowish color. I tried changing sides but got the same results. I'm not sure what's going on.
Old Sep 5, 2016 | 07:24 PM
jayfoxx357's Avatar
Bump
Old Sep 6, 2016 | 09:36 AM
DennisMik's Avatar
This may be an indication that you have the wires for high & low beams switched on one of those headlights.
Old Nov 16, 2016 | 12:08 PM
jayfoxx357's Avatar
Yea it seems so..I guess I'll take it to a shop that knows what they're doing because I dont
Old Nov 16, 2016 | 05:18 PM
RealityCheck's Avatar
You don't have to take it to a shop. The problem is that one pin in both plug sockets are switched. You have to carefully push out one of the pins and swap in a different spot of another pin.
Old Nov 16, 2016 | 05:39 PM
You shouldn't be using HIDs in stock housings anyway..
Old Nov 16, 2016 | 07:40 PM
max ride 41's Avatar
how true, looks stupid and just blinds everybody. plus, your headlights need a resto man.....
Old Nov 16, 2016 | 08:23 PM
jayfoxx357's Avatar
Yea i was gonna restore them..Can you guys enlighten me on my situation and recommendations.
Old Nov 17, 2016 | 12:08 AM
patience my friend, as reality check has stated : The problem is that one pin in both plug sockets are switched. You have to carefully push out one of the pins and swap in a different spot of another pin. take your time and watch what your doing and make sure it's hooked up properly. gl
Old Nov 17, 2016 | 08:14 AM
I would get a proper bi-xenon harness and bulbs if you really intend on keeping that set up.
Old Nov 17, 2016 | 04:58 PM
Zerodrag's Avatar
The Taiwan Cefiro H4 headlights work well with HID kits. Though the headlights are not a direct drop-in without modification, I believe.
Nykerinsd
Jul 30, 2016 06:40 AM
dealsgap
Apr 15, 2016 03:54 PM
Roblee
Mar 18, 2016 02:26 PM
tarun900
Mar 9, 2016 05:09 AM
sebastian2041
Feb 26, 2016 07:40 PM
