How do you drain coolant out the VE block?
Old Oct 9, 2016 | 05:46 PM
CandiMan's Avatar
Say Candyman 5 times
Just changed the water pump, added a coolant flush additive with straight water, would like to drain the complete system before adding antifreeze.
I was thinking of jacking up the rear end, disconnect the lower radiator hose at the radiator and apply compress air in the bleeder screw port.
I know the remaining water in the block may not make a difference so remember the tile of this thread, LoL
Old Oct 10, 2016 | 12:06 PM
DennisMik's Avatar
There is a drain plug in each side of the block to drain the coolant. See page 7 for the locations.
http://boredmder.com/FSMs/Nissan/Maxima/1994/LC.pdf
Old Oct 10, 2016 | 12:18 PM
CandiMan's Avatar
Get the freak out of here. After 20yrs of ownership (and having my own FSM) I never realize there's a drain plug, LoL
What's funny, over the years I've probably put my eye on those drains plugs numerous times and never realized what they were.
Hopefully they are easily accessible, especially the RH side next to the axle
Old Oct 10, 2016 | 03:32 PM
James92SE's Avatar
2 VE's are better than one!
I've never actually used them but I assume this is a drain plug visible here in my block (below the crank side freeze plug). This is the firewall side:
And another on the front of the block (above the freeze plug on crank side):
Old Oct 10, 2016 | 04:57 PM
CandiMan's Avatar
I'll see how easily accessible are those drain plugs when I get under there
Old Oct 24, 2016 | 11:58 AM
CandiMan's Avatar
FYI - Those drain plugs worked wonderfully. I was quite surprise to see how much coolant came out the left (radiator side) drain plug and this was after draining the radiator. The right plug, not as much as the left but enough.
Access to the plugs was easy. No special tool or having to be a contortionist. 14mm(9/16) socket, extension and rachet.
MaximaNoob1
20
Oct 13, 2016 02:53 PM
acamarillo
Oct 3, 2016 03:02 AM
Greenman03
Sep 19, 2016 06:34 AM
thankumuch
Sep 17, 2016 12:44 PM
MAXIMARK
Sep 11, 2016 03:03 PM
