2005 Max cranks but won't start
Old Jul 20, 2017 | 01:30 PM
Eljuane803's Avatar
2005 Max will crank but won't start
I have 2005 Max, 270,00 miles and AutoTransmission.
I replaced the flex plate, 2 Cam Sensor, Crankshaft Sensor, spark plugs, coil packs,valve cover gasket, battery, and alternator. I changed all them and still my car won't crank. I don't know what could be the problem to cause my car not too crank. Need HELP!!!!! Can anyone give me some sound advice.
Old Jul 20, 2017 | 02:22 PM
follyburr's Avatar
Not sure what it could be, but have you checked/replaced the starter? even the cables/wires.
Old Jul 20, 2017 | 03:21 PM
Eljuane803's Avatar
yes, check the starter. The starter okay. Going to check all wires now and put code reader on the car
Old Jul 21, 2017 | 10:05 AM
MadMax07SL's Avatar
If I'm reading it correctly, you meant to say 270,000 miles? With that kind of usage, hell it could even be the compression in multiple cylinders is so low you can't get a good explosion! Damn, I hope you get it narrowed down!
Old Jul 23, 2017 | 07:11 AM
Eljuane803's Avatar
The code reader is saying that I have bad crank sensor and cam sensor. I just change all three sensor before I change the flywheel. Do you think it could be timimg is off???
Old Jul 25, 2017 | 10:32 AM
Costee's Avatar
A great possibility. Check the compression.
