Won’t shift out of park and key not coming out
Old Mar 18, 2018 | 05:43 PM
maximusprime09's Avatar
hey alll,
2004 maxima se! so so basically it first happened leaving my buddies house about 2 weeks ago. I can’t shift my car out of park without using shift lock button. And then when I do put it in park with the shift lock button my key does not want to come out of the ignition no matter what I do with the steering wheel or even pressing shift lock while trying to remove the key. Nothing works. I’m stumped and done plenty of research and can’t seem to find an answer. No fuses are blown I checked them all. Brake switch is good cause the brake lights work, Any ideas of what it may be anyone ??
Old Mar 19, 2018 | 02:27 AM
Come on guys I know you’re out there ....
Brake lock solenoid?
shift lock control module?
its just hard to put a thumb on it ! There is multiple posts with this same exact problem but it seems they are all dead ends as nobody comes up with an exact conclusion on what fixed their problems, it’s really annoying having to leave the key in the ignition, well anyway right now my radiator is tore out and waiting for my replacement to come because it cracked at the top near the radiator crack (cheap plastic and original rad)
car has 125K miles on it , just did tranny fluid change, coolant change (two weeks and of course the rad bursts open like a ballon lol), and oil change with a puralator filter. Besides this the whole not shifting thing not being able to turn key all the way to the left and remove key from ignition thing is the only thing wrong with the car, could really use some help and good advice as I know it is out there from you smart people on this website. I lurked this site for awhile until I finally registered and decided to start a thread because of this problem.
Old Mar 19, 2018 | 12:39 PM
Costee's Avatar
Try out the shift lock module. It could also be that your key blade has worn out of alignment with the ignition cylinder.
Old Mar 20, 2018 | 09:30 AM
Where would the shift lock module be located do you know?
Old Mar 20, 2018 | 10:28 AM
Costee's Avatar
Under the dash, left of the steering column. The part number (for my 2006) is 28540-7Y00A. Should be the same for yours too.
Old Mar 20, 2018 | 11:57 AM
Tarzan's Avatar
I would try cutting a new key from a blank by the car's key code.
Old Mar 21, 2018 | 07:34 AM
how do you find out your specified key code?
Thanks for the replies
Old Mar 21, 2018 | 07:55 AM
is it a white square looking plastic “box”?
Old Mar 21, 2018 | 08:40 AM
Costee's Avatar
Yes, with a bracket. The part number is inscribed on it.
Old Mar 21, 2018 | 09:49 AM
Tarzan's Avatar
Key code should be on the glove box lock where it is easier to obtain. It would be a bit harder to obtain it from the ignition lock.
Old Mar 21, 2018 | 12:46 PM
Yeah my key will not turn all the way to the left and it won’t allow me to take the key out, I can only assume that the shifting problem and key problem are completely related or at least I hope so !
so this would be a relatively easy switch out?
Old Mar 21, 2018 | 01:25 PM
Tarzan's Avatar
Your lock does not know that the tranny is in park or neutral. Tranny interlock switch should be looked at.
Old Mar 21, 2018 | 05:04 PM
I get confused with all the components , there is interlock solenoid , shift lock module, tranny interlock switch what is that exactly?
i know it’s not the brake switch cause my brake lights all work and I have checked all fuses as well. There is another switch above the brake switch that also disengages when you depress the pedal and I’m unsure of what that is.
Old Mar 22, 2018 | 01:41 AM
Costee's Avatar
Most likely the ASCD cancel switch.
jrpaytonAlpha06
18
Nov 20, 2014 10:02 AM
StartaFire89
Feb 19, 2011 08:07 AM
seang86
Feb 18, 2008 01:18 PM
majordan
May 6, 2005 10:16 AM
