04 nissan maxima starter problem
Old Aug 28, 2018 | 08:45 PM
dudley wilson's Avatar
I bought a nissan maxima starter at hexautoparts.com last month.
Because busy with my works and went to another town for three weeks,so had no time to install it.
This monday,I put the starter in,it makes some noise but not turn the engine when I start it.
Can anyone explain what may be the problem? Or is it a defect one ? Do I need to do more testing ?
thank you for your time.
Old Aug 28, 2018 | 08:58 PM
follyburr's Avatar
Have you had your battery tested?
Old Aug 29, 2018 | 05:09 AM
Davisnathan49's Avatar
Try taking the starter off the Bell housing, leave thee electrical connection. With you watching the starter, have someone turn the key to acc/on but don’t start the car. See if the solinoid with engage and push the gear to connect with the flywheel.
Old Aug 29, 2018 | 06:58 AM
Tarzan's Avatar
With these instructions, I am afraid, the OP will get nowhere. The starter pull-in relay and starter motor do not engage when in ignition on. The easiest way to test is to use booster cables to jump the starter from the battery.
Old Aug 29, 2018 | 05:46 PM
Marlon Brizan's Avatar
The two reasons are the battery does not have enough power to turn the starter or you may have a bad starter solenoid.
Old Aug 30, 2018 | 08:48 AM
Tarzan's Avatar
This thread is very confusing while 2 Marlon Brizan's are arguing. I quit.
Old Sep 2, 2018 | 07:26 PM
It's fully charged.I have someone tested yesterday and he told me the starter solenoid was failed.
Then bought a new solenoid locally and install on the Hexauto maxima starter.
The whole process costs me $10 and one hour.
Now started with no troubles and very powerful.
Josh_9096
Mar 26, 2014 02:15 PM
nekromansur
Oct 11, 2012 04:51 PM
GarageToys
35
Jul 10, 2011 07:20 PM
Zirafa
19
May 28, 2004 07:10 AM
jqhao
Aug 11, 2003 03:42 PM
