tons of white smoke coming from exhaust.....
so, after getting it running perfectly 2 weeks ago i have white smoke coming from exhaust and i smell a ton of gas coming from exhaust as well., i am at my wits end on this car, my mechanic (
) thinks a possible cps sensor, there was a metal tube that came from the back of the engine with a wire that he broke when we did rear valve cover and he used steel stick to fix it. don't think that held, plus i heard a bad pcv valve can cause a clog issue and make white smoke as well. car is quiet when started, but it pops and sputters, and idles like crap plus the other issues. god damn is there someone near me in pa that can help me with this nightmare? suggestions please!!!!
Sounds like he broke the egr tube. Not sure how one can break something like that. The egr system re-circulates exhaust gases for better emissions..
Possibly dropped something down the intake?
Also he may have mixed up all the vacuum lines.
I just finished my front and rear valve covers today.
Haven't fired the car up yet
Originally Posted by JvG;9183113[color=#f1c40f
]Leaky fuel injector[/color]. Less likely, fuel pressure regulator.
I'd remove each plug, then notice a plug which will smell like gas and look 's bit wetter than the others.
so, you don't think it's possibly a warped cylinder head or a head gasket? all my injectors are basically new, would an intake leak cause them to go south if left unattended for awhile? car ran perfect for one day, then it started doing the white smoke and popping with a crappy idle. i smell a ton of gas as well coming from exhaust, i will start with looking at the injectors today and trying to see which one of them are faulty or leaking and checking all the hoses to make sure they're all connected. will check back in and let you guys know what we found.
Remember, new injectors can fail too. Happened to me once. I was like WTF, my problem is still here and I installed newly refurbished injectors. Turned out one of the new six injectors was crap.
Not at all. What makes you think that? Unless you really overheated the engine badly, this thought would not have crossed my mind.
No way.
A bad injector will do exactly what you described. Start with cylinders 2, 4 and 6 as they are the easy ones to get to. Maybe you'll get lucky.
No way.
Probably won't start on first try because too much fuel is being dumped. Injector is working...not working....working....not working...causing moments where the car is running well and other times where the the car is running like crap and even causing starting issues.
I bought Brand new oem original nissan fuel injectors from carid which were priced at 90 bucks a piece for 30 bucks a piece as they priced matched with amazon for me. The reason why I didnt buy them from amazon was they dont ship fuel injectors to california. Heres the part number Hitachi FIJ0023 and Nissans oem parts number is 16600-96E01 which is just repackaged and sold hitachi since they bought out unisia jecs who were the original manufacturing company. Just replace them all cause those pintle caps are burnt and brittle.
here's the thing, the injectors were all replaced in the last year or so. after the car warms up she runs fine. for me to replace all the injectors would be pricey and ridiculous imo. especially the back 3 which are a pita to get to. he dumped fuel injector cleaner in my gas tank and i think that crap chews away at injectors causing them to fail sometimes, so, he unplugged the front 3 and i agree they weren't all running the same but close. i am out of money and patience. she's running better and i will continue to monitor the engine performance and smell and listen to the engine. she's old and has 291,000 on her and i am sure some damage to 1 or more of the injectors happened cause i got sick of trying to figure out what was causing the p 0300 code among all the other codes. i would love to entertain replacing an injector or 2 but i smell no gas and i think the engine might be leaking anti-freeze through the exhaust a bit and has for years. not quite sure were else to go with maxy other than to do a pressure test, is there a video testing the injectors that i could watch so i know if any of them are truly faulty? thanks
Yeah your absolutely right about. I also checked the price there all around 80 dollars each now. Your also right about antifreeze possibly leaking through the exhaust as that can cause a p0300 misfire code especially since you have already replaced the injectors. Along with white smoke you would have raw fuel leaking through the exhaust which you dont im assuming. I hope your car can run and last you a little longer and you dont have any headgasket issues with your engine. Lets hope she stays running fine like you said it is now.
Get some help with identifying which. FUEL INJECTOR you need to replace.
You are also overheating your cat. They are more expensive to replace than a proper fix for your car.
By the way, I'd advise getting a second opinion from a good mechanic. Because a fuel pump is not the cause of your issue, which is too much fuel. Id believe a pump if the problem was underfueling.
One thing i never understood is why white colored smoke coming out from exhaust associated with injectors causing a rich condition? I would have thought a rich condition would result in black smoke. i know a lot of seasoned members associate the symptom and issue so i am not going to second guess this.
if your car is burning coolant through the exhaust system you will get a distinct "sweet" smell which should be easy to identify.
Could the problems you are having be maf related?
I have experienced over fueling in other cars. I got white smoke.
I have not experienced injector failure during the first 9 years and 90k mIles I drive my maxima.
I did have all the injectors rebuilt when had to remove my uim for an unrelated reason.
I have told you that you should suspect your injectors.
The Wizard has told you the same thing.
I have great respect for the Wizard.
Perhaps, just maybe, he and I know what we are talking about.
i'm not saying your wrong either. why don't i smell gas though? i mean at all? why am i not throwing a code for an injector and no c/e light? i mean, why is it running right 1 day and like $hit the next? ecu?
Once that happens, excess gas will go into the cylinders. That creates white smoke. Sometimes a gas smell. No code will set because the electrical portion of the injector is still ok. In fact, it could be rebuilt.
Injector failure is becoming very common with 4th Gen cars.
Not saying that the injectors are definitely the problem. HOWEVER, please read your first post in this thread. The one where you said that the car smells strongly of gas.
Please be advised..... there are companies out there which rebuild injectors for less than 20 bucks each. They disassemble them, clean and rebuild them. They include the o rings needed for installation as well. I had RX Injector in Houston rebuild all 6 of mine. The car ran better once I was done. None of my injectors leaked yet. But I had the uim off for an other reason. So I took the opportunity to rebuild them at my convience. Much better than wait for an inevitable leaking injector on the rear bank during a blizzard or heat wave.
If you are looking to save money and like to DIY jobs, you can rejuvenate your existing injectors with by applying new screens, o-rings, and pintle caps. I'm coming up on 5 years with running the injectors I rejuvenated back in 2014.
https://maxima.org/forums/test-posts...struction.html
the exact same thing happened to me and I got the same responses then. One member told me it was absolutely the Fuel Pressure Regulator.
Even 2 reputable auto repair shops told me it was anything from a shot motor to bad injectors. I replaced the fuel pressure regulator. It was a cheap and easy job.
That was 2 years ago. Car has been running perfect ever since.
Your experience is helpful.
99MAXSE-L
Jan 16, 2007 02:17 PM
TommyT
Oct 10, 2005 12:15 AM
Black-i30t
Jul 21, 2003 09:11 AM
