98 Max shifter won't go into 1st- auto trans
Old Nov 23, 2019 | 04:53 PM
ladyvolsrule's Avatar
Car wouldn't shift out of first-hand replaced shift solenoid now won't move. The shifter will not go into first gear....can anyone help? Any ideas?
Old Nov 23, 2019 | 10:44 PM
KP11520's Avatar
What about when the car isn't running? Could be a speed sensor on the transmission behind the driver's wheel and fender liners.
If not that, shifter linkage and/or shifter cable might be corroded. IT happens a lot with parking brake cables as well.
Year, model, mileage and location provide clues, along with history if possible,. that's how it works in forums.If you don't provide much, that's what usually becomes the result.
Old Nov 24, 2019 | 12:12 PM
JvG's Avatar
JvG
Define : won't go into first gear.
Do you mean that the shift lever won't go into first gear, if you shove it there by hand?
Is it possible if the car is not running?
Or is it possible if the car is running?
Does it go into neutral or reverse.
does it go onto other gears?
Can the car drive in second or higher gears?
WE NEED MORE INFORMATION.
Old Nov 24, 2019 | 12:40 PM
aembleton's Avatar
Had the same thing happen when I replaced the solenoids in my I30. I opened the trans up and found that I hadn't pushed the rod that connects to the shift lever up far enough so it was not engaging the shift lever with the trans. I did that and the car drive and goes into gear perfectly now. Also check remove the trim around the shiftier and see if the shift interlock solenoid is moving when you push the brake. Mine failed and I have to use a Flathead to manual push it into gear.
Old Nov 26, 2019 | 05:16 PM
Aembleton that is exactly what it was thanks! Unfortunately the shift solenoid repair kit made no difference...it goes in drive fine but will not shift into second gear...reverse is fine too...any ideas on that? Really hoping trans isn't shot
Old Nov 26, 2019 | 08:04 PM
aembleton's Avatar
check the fluid level/type of fluid. Also if the trans valve body bolts are too loose or tight it may cause issues with shifting. My I30 had these issues but it eventually remedied itself.
Old Nov 26, 2019 | 08:07 PM
aembleton's Avatar
Also are you getting codes/ is the O/D light flashing
Old Dec 1, 2019 | 01:34 PM
Trans shift solenoid repair kit did not change the issue at all. Yes, pan bolts tight. It shifts in reverse & goes in drive strong, but will not shift into second. Diagnostic codes P0325, P0110 & P1105 is what it is now showing. Checked the tps it showed good, checked the map/baro sensor also tested good. I suppose the transmission could be toast, but I am not giving up just yet. Anyone with any ideas please?? O/d light not flashing
Old Dec 4, 2019 | 03:23 PM
martyl45's Avatar
As JVG had asked earlier, can you shift into 1st and 2nd with the engine off?
Will it not engage 2nd gear or are you unable to shift into 2nd gear?
Old Jan 1, 2020 | 10:38 AM
Yes martyl45 it will shift into all the gears with the engine off it will not shift from drive into the next gear going down the road..I really don't know what to try now
VQ35maxima=Beast
Dec 14, 2017 04:35 PM
NElsonAQuino
Jun 10, 2008 07:41 PM
pmohr
Jul 8, 2006 10:37 PM
Street Reeper
Aug 21, 2003 07:44 PM
Dave B
Dec 4, 2002 01:28 AM
