I was looking up spark plug tube seals and came up with two different part numbers. 13276-31U1A and 13276-31U21. Different prices also. Both are tube seals, and both will supposedly work. Anybody have an idea to which one is correct?
Correct, they are part of the Fel-Pro set. I was just curious to why the OEM set has two part numbers and two different prices for tube seals?
Sometimes manufacturers have updated parts with a different rubber type. For example the early 2000s Toyota Corola has a intake manifold gasket which likes to leak air when it gets old. They still sell the iffy gasket for a lowish price , and the proper updated gasket at a higher price..
I suppose the low price one works for a quick flip or for a car one wants to sell soon. Some people want to pay as little as possible, others pay more up front so they never need to do the project over.
You will see with the 31U1A that both sides look similar. With the other seal, one side is completely flat
Also see this earlier thread from a few years ago. The way I had it was wrong, which should've been obvious by the shape of the seals, but all the other how-to's I could find at the time looked like (the wrong way), which may be due to the seals included with other valve cover gaskets, or perhaps the different part numbers you bring up. I used the Mahle valve cover gasket set, which was called Victor Reinz at the time
The two part numbers matter because one of them is for the front valve cover and the other is for rear valve cover.
Yup there supposed to be different. Here are the images taken by part number and it states Quantity of 3 for each part number.
On Infinitipartsdeal, it states quantity of 6 for each part number, giving you 12 tube seals. And if they were truly different from front to rear, they both would not turn (yellow) highlighted when you click on one of them. I believe JvG is right when he said it’s an updated part with the old one still being available for sale.
