3.0 valve covers on 3.5
Old Jul 28, 2020 | 12:41 PM
uptownsamcv's Avatar
been looking online on if this can be done and was wondering if anyone had any info on it. im going to be doing my intake manifold spacers and.it would be nice if i could use the metal 3.0 ones with 3.0 coils and OEM seals so i wouldnt have to worry about pulling off the plenum for a long time. i mainly want to do the rear one.
Old Jul 28, 2020 | 12:56 PM
Child_uv_KoRn's Avatar
Bad *** Newb
Drill out the tube seals and replace them.
Old Jul 28, 2020 | 01:09 PM
schmellyfart's Avatar
Not gonna happen. Cam cap profile is different and the IVT solenoid will be in the way.
I have a set of spark plug tube seals and hole saw jig for the plastic valve covers for sale. PM if interested.
Old Jul 28, 2020 | 02:32 PM
RA030726's Avatar
I'm nutty for Nissans
01-04 3.5 Pathfinders/QX4 had metal covers. Hard to find apparently.
Jig you say! Tell us more. What's it made from? Replace with 3.0 seals?
Old Jul 28, 2020 | 03:12 PM
Bad *** Newb
You just stick a hole saw on it, that's it. You can buy the tube seals online.
Old Jul 28, 2020 | 06:48 PM
00-01 3.5 pathfinders have the metal covers and you'll need the pathy coil packs as well. 02-04 are plastic and use the same coil packs as the 5.5 gen Maxima 3.5.
I spent far too many hours researching and checking junkyards to avoid buying new valve covers for my 02 Pathfinder as OEM were $380.
Anywho, I 3D printed the Jig to align the hole saw to cut away just enough of the PCV baffle plate to replace the tube seals without cutting through the plate, and keep the hole saw from walking, photo below.
Theres a guy on my350z that sells the seals for ~$60 plus core charge for his jig, I felt that was a little high so I stole these seals out of a cheap pair of aftermarket valve covers.
Turns out that the aftermarket valve covers use the same spark plug tube seal as the OEM valve covers, but I was not able to find a source for the seals.
3.0, 00-01 pathfinder 3.5 (metal), and seals listed for a ~04 altima will not work.
I've also read reports of people double stacking some 2.0L Honda tube seals and making it work.
Old Jul 28, 2020 | 07:06 PM
RA030726's Avatar
Damn, so that's why the metal Pathfinder ones are so hard to find. They didn't make them long.
I'm so glad I have not tried to drill out any oil seals. Without a jig and seals I'd be dead in the water.
Old Jul 29, 2020 | 06:59 AM
for now I've been running.cheap ebay purchased valve covers but installed themwith Fel-Pro gaskets and they have been holding up good since last summer. i did the valve covers rwice vause the gaakets that came with them hot hard and brittle and.leaked within a month. for now the Fe up great but who knows how long it will be before the tube seals start leaking. I also installed a PCV valve I got from the parts store just in case...
BoostinBy
Feb 25, 2015 08:40 AM
TDotMax
Mar 9, 2013 08:43 AM
maxam
Nov 20, 2009 02:39 PM
danman700
May 9, 2009 09:29 AM
JClaw
Dec 3, 2006 12:38 AM
