Testing Swapped Ignition Coil
Old Aug 21, 2020 | 02:45 PM
97maxy's Avatar
I'm getting a P0304 Code. Which I believe could be a bad cyl #4 ignition coil. As I've read here I will swap it out for the one next to it, say cyl #2.
Now my question is how do I know if the problem moved to cyl #2 ? I'll clear the codes, swap and then do another reading. But I'm not sure if I'll get a reading right away, or will I have to wait till all the checks are 'ready' for the OBD2 Scanner to give me another reading ?
So, if I clear the code, swap and do a reading will I get another code (P0302) right then and there ?
Thanks...
Old Aug 21, 2020 | 07:42 PM
May get the new code right away, may take a few drive cycles.... don't worry about it, just do it and see if the code moves to cylinder 2.
Old Aug 22, 2020 | 04:10 AM
97maxy's Avatar
I just swapped the coil and checked but didn't get a code. So yes, I'll have to do a few drive cycles and see. Hopefully that will be it.
Thanks...
Old Aug 24, 2020 | 08:42 PM
CMax03's Avatar
The easy way to solve Coil pack issues is using an Ole' School timing light placing the inductive pickup clamp around the coil pack pigtail...No need to wait for the ECU to load the problem it's live and visible!
Old Aug 25, 2020 | 04:15 AM
97maxy's Avatar
Could you elaborate on that, not sure how that would work.
plat
May 16, 2018 09:34 PM
KOWGIRL47
Apr 9, 2017 06:03 AM
watut
Mar 10, 2013 06:39 PM
ti2tmax
Jan 12, 2012 08:21 PM
Driven EF9
Dec 6, 2004 07:40 PM
