Po600 code - comm link
Hi,I'm trying to resolve a P0600 code on my 98 maxima. The EC Manual say to check for continuity between terminals on ECM and TCM. The terminal pairs are (ECM - TCM) 65-47, 66-38, 73-10, 74-11 and 77-12. I'm not getting continuity between and of the pairs. I have my battery disconnected although the EC Manual is asking to turn the ignition OFF only. I find it strange that continuity doesn't exist between any of the terminal pairs. Am I doing something wrong. Any help would be appreciated. Thanks in advance.
It might be your speedometer cluster, first try and clean the connection on your speed sensor, I have seen numerous 95 96 maxima have this code and the cluster wound up being the issue, if you have a spare try this before changing the tcm or ecu
Thanks for the feedback. MaxFever1987- I haven't been back at it yet but I will try the cluster thing.
vqmaxman - I just find it strange that there were no results in any of the wires i checked for continuity. Which means that the entire harness section between ECM and TCM is cut right through. Don't you think that's unlikely?
Magikone69
Apr 27, 2004 08:38 AM
Keven97SE
Sep 5, 2000 01:07 PM
