How to clean CV boot from oil?
Old Dec 16, 2021 | 01:21 AM
RITE's Avatar
Some motor oil is leaking on it slowly. What product should I use to clean the rubber so that it does not cause the rubber to damage or wear out faster? I had the axle replaced a year ago and don't want it to go bad again too soon.
Old Dec 16, 2021 | 03:35 AM
Turbobink's Avatar
Relax … it’s a CV boot. It’s, for the most part, designed to withstand some fairly harsh conditions.
I find that blue Dawn and water works quite well for most things.
Old Dec 16, 2021 | 09:11 AM
KP11520's Avatar
I agree with Tb, Dawn is an excellent oil/grease breaker without being harsh on anything else.
Another product I also use is Simple Green's HD PRO concentrate, sold in a gallon jug at Home Depot.
Even when I dilute it 3 parts water to 1 part concentrate, it pulls all the oil out of my hands and they crack open. I only use this with gloves on now. SAFE on aluminum as well, like Dawn.
https://www.homedepot.com/p/Simple-G...3421/100550784
Old Dec 17, 2021 | 06:14 AM
CS_AR's Avatar
To clean excessive mud and road rime, I use an old product named Ru-Glyde. It is a tire lubricant mostly used for mounting tires. I make it an annual ritual to clean CV boots exposed to off-roading conditions. It cleans and helps to condition boot material. I buff it dry after use. Sometimes I use it to rejuvenate old bushings and grommets that are no longer available. I keep it in a squirt bottle. A gallon usually lasts 7 years.
  • Ready to use tire mounting lubricant, no mixing necessary!
  • Protects against bead damage and help seat tire beads properly on the rim
  • Will not cause rust or tires to slip after mounting and balancing
  • Removes rubber squeals in bushing and grommets
  • Restores new look to floormats, tires, and upholstery
Amazon Amazon
mytrplseven
Jul 2, 2012 04:58 AM
str8max
21
Apr 14, 2008 07:19 AM
kingrukus
52
Dec 15, 2006 08:31 AM
VIP Maxima
Detailing
Oct 17, 2005 12:58 PM
vinny1978
Aug 12, 2002 08:42 PM
