Push rod...catastrophic failure?
I took my 2013 Nissan Maxima in to the mechanic for some fairly typical repairs and they told me nothing is worth fixing because the Push Rod is failing, rendering the engine doomed. I've never dealt with a push rod situation before so I'm at a loss. Can anyone offer any advice or additional info on a push rod failure and if it means the end of the engine? Thanks!
This just seems like an extreme assessment of a Maxima engine with only 135,000 miles that has been well-maintained and driven with care.
I’m in agreement with Prophecy … or maybe just leave it alone.
I don’t recall that crank and/or rod issues are typical, common or even uncommon in the VQ35.
If it truly does need a rod replacement or the rod fails and the engine self-destructs, the end result is the same.
Are any of these symptoms present?
Knocking noise;
Low oil pressure;
Low oil level and/or high oil consumption;
Overheating.
Any of these present?
Knocking noise;
Low oil pressure;
Overheating.
Many years ago when I had my 3rd gen in college a shop that did the alternator said they put a cheap reman in because "the transmission is slipping so bad" and said they didn't do transmission work so take it elsewhere. Shifted fine to me but took it to an Aamco who drove it around a few blocks for free and said the place is full of sht & the transmission is fine. Some guys make obsurd diagnoses over nothing
Push rod, no. VQ's don't have those. Connecting rod, maybe. More likely it's the bearings.
RECORD_ID: 362627
NHTSA Item Number: 10054120
Replacement Service Bulletin Number: N/A
Date Added: Dec 21, 2013
Bulletin Number: NTB-12-071-A
Date Posted: Dec 17, 2013
MFRINTERNALCAMPAIGNID_SOFTWAREVERSION: N/A
COMMUNICATIONTYPE: Service Bulletin/Repair Instructions
Make: NISSAN
Model: MAXIMA
Year: 2013
Component Name: ENGINE
MFRCOMPONENTSYSTEM: N/A
MFRCOMPONENTSUBSYSTEM: N/A
Summary: NISSAN: KNOCKING NOISE COMING FROM NUMBER 1 CRANKSHAFT MAIN BEARING, WAS NOT HEARD AT COLD START, WHEN VEHICLE IS LIFTED, KNOCKING IS HEARD, OR AT WARM IDLE, NOT HEARD AT HIGHWAY SPEEDS OR SITTING WITH RADIO ON. MODEL 2009-2014 MAXIMA
RECORD_ID: 362627
Make: NISSAN
Model: MAXIMA
Year: 2013
RECORD_ID: 2597305
NHTSA Item Number: 10192284
Date Added: May 10, 2021
Bulletin Number: NTB12071A
Make: NISSAN
Model: MAXIMA
Year: 2013
Summary: IF YOU CONFIRM A knock noise coming from the # 1 crankshaft main bearing: ACTION 1. Remove the # 1 main bearing (upper and lower halves), per the Service Procedure in this bulletin. 2. Select and install a new # 1 main bearing that is one grade highe
Make: NISSAN
Model: MAXIMA
Year: 2013
Dougn
Nov 14, 2005 05:44 PM
