HVAC Blower intermittent shut off
Old May 21, 2025 | 07:51 AM
Sleepyhawk's Avatar
2001 Maxima 20th Anniversary Edition
Automatic heat and AC. (not sure what the actual name is)
I'm looking for advice on how to solve the following issue. The AC/heater blower motor will randomly stop working and then just as randomly turn back on. When it works it functions on all speeds.
The 15 amp fuses are good.
The relay clicks as expected when key is in the ON position.
When working the fan voltage is: Off: .5v 1: 5v 2: 8v 3: 10.8v 4: 12.4v
When not working voltage is: Off: .5v 1:.35v 2: .32v 3: .29v 4: .24v
Testing was done in the ECON mode.
Thanks for checking out my post.
Old May 21, 2025 | 08:21 AM
uptownsamcv's Avatar
looks like your on the right track. I know sometimes when blower motors start going out they may run intermittently or make noise.
Old May 21, 2025 | 10:02 AM
TallTom's Avatar
My money is on the blower motor failing. $40 from Rockauto and the swap isn't too hard to do.
Old May 21, 2025 | 10:06 AM
Sleepyhawk's Avatar
I recently changed the blower motor and everything functioned correctly for about a month.
Old May 21, 2025 | 11:45 AM
slvr2KSE5's Avatar
you need to replace the part in your first picture. "fan control amplifier"
Old May 21, 2025 | 12:12 PM
Sleepyhawk's Avatar
That will be my next move.
Thanks.
dmack69
Apr 29, 2024 10:38 AM
a3111214200
Jun 19, 2023 06:28 AM
threebetyou
27
Jul 22, 2010 07:52 AM
MadXtreme01
May 30, 2007 07:31 PM
