Blower not working
Old 04-24-2024, 12:40 PM
dmack69's Avatar
Blower not working
Hello Guys<
My 99max,,,The Air stopped blowing...... I repaired a pin hole in the AC line......before I injected R34... the heater worked......one day the fan blower would not come on....
I replaced the 2 NEw Fuses under the hood....and the 2 Blower fuses drivers side door.....nothing!!!..Replaced with New blower and Resistor..........Nothing.....swappped out relay drivers side fuse panel TOP one......NOTHING! ....hit the JY and got 2 control panel tried both.... NOTHING!!!........NOW the connector to the Manual Control panel looks like 2nd from right burned a little bit...........I was thinking of replacing with a good one from the JY??2 Tears coming down right now its going to be HOT this summer lol.. I have searched the Maxima Forums! Any Idea's guys? Did I miss somethng?...thank you for your input!
I was going to cut this one out and splice the new in? due to the pin on rt 2 to last is burned.
dmack69 is offline
Old 04-24-2024, 04:10 PM
chrome91's Avatar
Did you unplug the blower motor connector and use a DVOM or test light to confirm there's power going to the connector with the fan switched on?
chrome91 is offline
Old 04-24-2024, 05:38 PM
dmack69's Avatar
Thank you for your input......Yes sir I think I did....from the connector to the blower on HI
Yes sir,,,I think I did....
dmack69 is offline
Old 04-26-2024, 06:32 PM
Vladimir_K's Avatar
I would connect a black wire on meter to COM (not to 10A) and do voltage measurement one more time.
Vladimir_K is offline
Old 04-29-2024, 08:44 AM
dmack69's Avatar
Thank you sir.....I will try that.
dmack69 is offline
Old 04-29-2024, 08:48 AM
dmack69's Avatar
Resolved Non-working Blower
Resolved..............the Freaking Blower Relay****......diagram has it being on Top.....Under Driverside next to Fuse box........After replacing everything because Ima DA!!! thinking I got $$$$$ dropping out my Buttthole! It turned to be the Bottom Relay for the blower and working NOW!!! Thank you again for anyone/Everyone who chimed in....
dmack69 is offline
Old 04-29-2024, 10:38 AM
Vladimir_K's Avatar
If your resistor and motor are good and you have +12V on motor terminal than the push control unit is a problem if manual mode used.
Smackasmith
02-01-2016 12:40 AM
Prophecy99
02-16-2015 09:56 AM
jasonmax
11-06-2007 03:48 PM
MadXtreme01
05-30-2007 07:31 PM
prainsberger
11-27-2002 01:48 PM
Quick Reply: Blower not working
