No tachometer in 6MT
Old May 23, 2025 | 03:14 PM
TheLastMan's Avatar
My tachometer stopped working. Everything else in the instrument cluster works as it should, but the tachometer needle doesn’t budge. No OBD codes, either.
I checked the connections and wires leading to the instrument cluster and they look fine. Also, I use a scanner connected to the OBD-II port while driving and the ECU is getting RPM information, so the problem is not between the transmission and the ECU. So must be between the ECU and the instrument cluster.
Thoughts on tracking down the problem?
Old May 23, 2025 | 04:14 PM
uptownsamcv's Avatar
i think I heard before that a bad crank position sensor can cause the tach not to work and will also cause you to have a hard time starting the engine.
angelmaxima
Apr 25, 2010 06:20 AM
ozzombie13
May 17, 2009 01:12 PM
kingrukus
Nov 3, 2005 01:21 PM
MaximaVQ97
Apr 15, 2003 11:01 PM
geo1317
Jun 12, 2002 04:49 AM
