Tyres and Rims Suggestions
Old Sep 4, 2025 | 05:40 PM
Naz9r_'s Avatar
I got a 2003 maxima that has the 17 inch rim, and it is so bumpy in the road and I can feel every little thing in the ground and it's annoying, I have a 215/55/ZR17 on the rear and 225/55/ZR17 on the front, (like the one in the attached photo)
And they are made in china and the front are old, the rear tyres are sorta new, but I know maxima's are not the most comfortable these days, but I asked a friend of mine about changing the rims to I believe the 16 inch rims (which are seen in the attached photo) and he said that it will increase the ride comfort because now the tyre is bigger and the rim is smaller, I don't know what is the exact tyre size for this 16 inch rim, I searched on google and it says on some website and it says 205/65/R16, I don't know if it's right or not, can anyone suggest what to do in this situation?
Old Sep 5, 2025 | 05:01 AM
Prophecy99's Avatar
you need to have the same size tire all around, use a tire size comparison website of your choice. you can upgrade tire sizes with in reasonable limits. on my current car i went from 245/40R19 to 255/40R19,
make sure you spell tire correctly. keep searching and look around here you may find better results.
Old Sep 5, 2025 | 05:52 AM
Naz9r_'s Avatar
Yes I wanna change all four tires to the same size, but I wanna know if I could change the rim size from 17 to 16 which is seen in the photo, so I can get more comfort because it's 205/65/R16 according to some tire size website I saw earlier, and if that will geniune increase the comfortability of the car when going into normal road potholes and not being so bumpy.
Old Sep 5, 2025 | 06:32 AM
RA030726's Avatar
I'm nutty for Nissans
215/55r16 is stock. They are 25.2" in diameter.
215/50r17 is stock. They are 25.5".
Depending on the wheel width,
195/60r16 are OK at 25.2".
205/60r16 are OK at 25.7".
245/50r16 are OK at 25.6".
205/65r16 are too big at 26.5".
Old Sep 5, 2025 | 06:40 AM
Naz9r_'s Avatar
For this rim, what size do you recommend for comfort ride?
Old Sep 5, 2025 | 07:16 AM
uptownsamcv's Avatar
what kind of shape is your suspension in?
how old are the struts?
are the suspension bushings still original?
Old Sep 5, 2025 | 07:26 AM
Naz9r_'s Avatar
I believe it's thr original shape suspinsion my fsther did change it 3 to 4 years ago, and the bushings is original and I do have to change them because they make an annoying sound whenever I get into a bumpy thing in the road.
Meli1313
21
May 1, 2014 07:05 AM
JaKillz2
Tires and Wheels
Dec 23, 2006 03:44 PM
jadismi
Tires and Wheels
Aug 10, 2003 07:31 PM
speedemn
19
Dec 1, 2002 09:09 AM
MichaelAE
Feb 6, 2002 11:40 PM
