i live in central Florida and we just recently had the coldest weather in a long. my car was sitting since I had to redo my polyurethane lower engine mounts , so I was waiting for the cold weather to pass and fix it. the car doesn't have heat and I have my van so I wasn't in a rush to fix it. when the cold weather passed I changed them out and took the car for a short drive and the morning after i see a puddle under the car.
has anyone ever experienced anything like this?? it's getting close to 3 years since I put in the 2014 engine, I wasn't expecting an oil leak this soon 😒
at first I thought it had something to do with the clutch hydraulics cause the pedal was stuck to the flooor when I got in the car. sucks having to pull the tranny again, I just put a new clutch in 2 months ago.. .
maybe? is it confirmed engine oil? it looks to be coming out of the bell and i would expect the slave to be leaking down the front area of the trans.
did you change the rear main when you did the clutch? if so thats where my money would be. half moon seals generally make it 10 years before they start leaking.
it's leaking pretty fast, I'm thinking it's the rear main as well. i had checked the level, let it warm up than reved it to 4k a few times. when I looked underneath I could see it dripping out.
I had put new rear main seal and resealed the upper pan when I did the swap around 3 years ago.
I actually went with Fel Pro. when I did the rear main seal on the original DE I picked up an OEM rear main seal at Nissan and it was a Fel Pro. I never had any issues over 10 years with that engine so I wen't with Fel Pro on the 2014 engine. I won't be doing that again.
NOK is the original supplier but it looks like OE nissan is the best price.
12296-ja10a
NOK seems to be the way to go, i've had my 2JZGTE rebuilt ground-up twice. First builder used Fel-Pro but had a Jap specialist shop do the second build and said they won't use anything but NOK on Japanese vehicles and Fel-Pro isn't really the way to go
i threw in the Bar's like a half an hour ago at the auto parts store. the drive home was 5 miles, I'm letting the car idle for now. as of right now, I'm not seeing any drippage as the car is idling in the drieway.
this is what i meant by the "cracked head" (cylinder heads)
the guy using the bar's leak had unknown source coolant being mixed with his engine oil, and has slowed down the coolant after further oil changes using bar's leak
I drove quite a fews miles after putting the stuff in but I think the leak has only slowed down as the oil level has dropped. going to pull the pan and tranny next monday
as it turns out, it was worst than I thought. a few of the nuts that hold the friction plate on the JWT flywheel came off and put a hole in the oil pan.... the Fel-Pro seals had nothing to do with it but I did pick up all the seals I need at Nissan.. I went ahead and ordered a Nisformance flywheel and ARP pressure plate bolts
im tempted to buy the FW off you but i also think ill be going with the nisformance unit
one of the thread inserts where the pressre plate bolts on to always gave me problems but never came loose. not sure what happened this time, i torqued the friction plate screws all to spec and even rechecked to make sure I didn't miss one.
you can have it for free if you wanna see what a machine chop can do with it. it looks a lil rough but the engine started up and ran fine with it installed.
after taking a closer look, it appears that 2 of the thread inserts on the same side came loose.
uneven pressure on the disc and friction plate caused a hot spot which made the plate lift and pop a few of the friction plate screws. one of the nuts made impact on the oil pan causing the hole...
yeah thats scrap metal. main reason i was going to go with the nisformance unit. all one piece
I ordered the Nisformance flywheel monday. I went back later in the evening when I decided to order ARP bolts and noticed the flywheel was marked as out of stock on the site.
more companies need to jump on making solid flywheels so people can ditch the dual mass flywheels. from my experience they arent worth the hassle. the springs in them dont seem to last
after a few delays I got it back together and running. I really like the Nisformance flywheel, no more chatter. I also went with ARP flywheel and pressure plate bolts.
